Thread started 21 Jun 2011 (Tuesday) 16:00
First IR attempt
Logicus
Joined Nov 2010
Jun 21, 2011 16:00 |  #1
I picked up a cheap ir filter (Zykkor IR720) to play around with before sending my XSi off for IR conversion. Well, I used my 5DMkII, not thinking about the fact that it would have a stronger IR filter than the XSi, so shots in sunlight were taking over a minute at f/3.5 and ISO100. So now I'm out to try it again with the XSi to see if my results are any better. I think the filter (though a cheap one) is decent enough as far as the quality of the glass, as the center is fairly sharp. Hopefully the next will come out better.
After channel-swapping and some other coaxing in Photoshop:
IMAGE: http://farm4.static.flickr.com/3302/5847185633_a86be564d6_b.jpg
IMAGE LINK: http://www.flickr.com …gicusaeturnus/5​847185633/  (external link)
Something Different (external link) by Jason Haley (external link), on Flickr
Directly from the camera:
IMAGE: http://farm4.static.flickr.com/3155/5847762616_0ca235b67b_z.jpg
IMAGE LINK: http://www.flickr.com …gicusaeturnus/5​847762616/  (external link)
something diff orig (external link) by Jason Haley (external link), on Flickr
My Gear List
My flickr (external link)
My flickr photos organized by Lens Used (external link)
rick_reno
Jun 22, 2011 07:55 |  #2
wow. bold colors, i like the top one the best
Logicus
Joined Nov 2010
Jun 22, 2011 12:29 |  #3
rick_reno wrote in post #12637973 (external link)
thanks, the top one is actually the bottom one after a lot of meddling in photoshop.
I think with an older camera (with a weaker ir filter) I'll be able to get better color and sharpness out of the shots. We'll see!
Thanks again!
My Gear List
Acamacho
Jun 22, 2011 15:10 as a reply to  @ Logicus's post |  #4
Try setting a custom white balance next time. Take a picture of the grass and use that for the white balance. That way you have a more workable image if you save JPG. It won't be so red, sort of like this:
http://www.lifepixel.c​om …traight-out-of-camera.jpg (external link)
I do like the color scheme going on though in your processed version!
Gear | Flickr (external link) | Fluidr (external link) | Feedback
Logicus
Joined Nov 2010
Jun 22, 2011 15:12 |  #5
Acamacho wrote in post #12640382 (external link)
thanks for the info! will be doing that on this venture... heading out now, actually...
My Gear List
jblaschke
Gallery: 6 photos
Jun 23, 2011 10:30 as a reply to  @ Logicus's post |  #6
Yeah, Canon has significantly improved their hot mirrors in the 50D and 5DII. Even with long exposures using them for lens filtered IR is a challenge.
One thing you might to to improve your images is cover the viewfinder when you shoot. There's a rubber sheath attached to your camera strap that fits over the eyepiece when you remove the rubber eye cup. This will keep stray light from leaking in when the mirror's up during exposure and degrading your capture.
Canon 7D | Canon 50D IR modified | Canon EF 70-200mm 2.8 IS L | Canon FD 500mm 8.0 Reflex | Canon EF 85mm 1.8 | Canon EF 50mm 1.8 mk I | Canon EF-S 10-22mm | Tamron 28-75mm f/2.8 | Meade 645 (762mm f/5)
Model Mayhem (external link) | DeviantArt (external link) | Lisa On Location: New Braunfels Photography (external link)
1,244 views & 0 likes for this thread, 4 members have posted to it.
First IR attempt
1338 guests, 131 members online
