Thread started 21 Jun 2011 (Tuesday) 16:46
Whats on top of your monopod?
Silverstonev8
Joined Jun 2011
Jun 21, 2011 16:46 |  #1
I am wondering what most of you use for a head on your monopods.
Chris -- Gear List
Jon
Joined Jun 2004
Jun 21, 2011 17:15 |  #2
RRS MH-01 with the RRS lever clamp. But then I have L clamps and long lenses. I used to use the Manfrotto 486RC2 back before I shifted to Arca-Swiss and L plates (spend a day flipping between portrait and landscape with your ball head and the virtues of an L plate come to the fore).
Jon
Cocker Spaniels
luciddreamer
Jun 21, 2011 17:19 |  #3
My Berlebach monopod comes with a built in tilt head. The lens I use on it 99% of the time has a built in orientation flip. Works for me.
materialism ~
preoccupation with or emphasis on material objects, comforts, and considerations, with a disinterest in or rejection of spiritual, intellectual, or cultural values.
Jannie
Jun 21, 2011 17:28 |  #4
Manfrotto monopod and RRS quick release bracket and L plate.
Ms.Jannie
"When you come to a fork in the road, take it"!
1DMKIII, 85LII, 24-70L, 100-400L
DavidR
Jun 21, 2011 17:39 |  #5
Jannie wrote in post #12634462 (external link)
I don't use a monopod much, but if I did, I would do this.
Sony a9II
xhack
Jun 21, 2011 18:04 |  #6
I have a Manfrotto 488 atop my 055 tripod, which I find meets my (relatively) undemanding needs. Yes, It does droop marginally with a 100 macro when mounted on a camera battery grip, but I can live with that. Otherwise, a sensible middle-of-the-road compromise which works well.
As for monopods - well, it's a different world. I went down-market with a Manfrotto 496. Smaller and not so featured. Cutting corners? Maybe. But not necessarily. A monopod is used in a different way - the photographer is holding the camera dynamically; the monopod/ballhead need only provide a rigid and secure path to ground. So there's no imperative for a really heavy duty outfit at the top of the pole. It works for me.
~ Wallace
Jon
Joined Jun 2004
Jun 21, 2011 18:12 |  #7
More important, a monopod head doesn't need to incorporate pan capabilities. The Manfrotto 486 and 488 heads were about equally capable; it's the pan of the 488 that made it the preferred choice for tripods while the 486 without pan went on the monopods.
Jon
Cocker Spaniels
Silverstonev8
Joined Jun 2011
Jun 21, 2011 18:39 |  #8
So if I go with the L plate I could just mount an arca quick release plate right on top of the monopod without a head?
Wouldnt that be too restrictive on vertical range?
Chris -- Gear List
RPCrowe
Joined Nov 2005
Jun 21, 2011 18:41 as a reply to  @ Jon's post |  #9
Kirk MPA-1 which I use with my RRS L Bracket for lenses without a tripod ring and a standard Arca Compatible plate for my lenses which are equipped with a tripod ring.
IMO, using a camera on a standard ball head in the portrait position on a monopod is very awkward because the camera is hanginging cantilevered over the side.
If I did not want to go to the expense of switching to an Arca Compatible system (which is the best thing since sliced bread) I would use a Manfrotto monopod swivel and Manfrottos generic L bracket. Not as slick as the RRS L bracket on an Arca Compatible head but, it keeps the center of gravity ov the camera directly over the pod in both landscape and portrait positions.
Of course if you are using a lens with a tripod ring, the question is moot since the lens remains over the monopod when the camera is in both portrait and landscape positions.
However when shooting field sports when most of my shots are directly ahead I attach the tripod ring directly to the monopod. I always use the monopod with longer lenses that have tripod rings when shooting field sports.
Silverstonev8
Joined Jun 2011
Jun 21, 2011 18:54 |  #10
I do have an arca plate on my lens and a regular arca plate for my camera but I can exchange the camera one for the L bracket.
Chris -- Gear List
Jon
Joined Jun 2004
Jun 21, 2011 18:59 as a reply to  @ Silverstonev8's post |  #11
Silverstonev8 wrote in post #12634937 (external link)
Depends on what you shoot. Unless you need a great deal of up and down adjustment, you can tilt the monopod. They don't have to be absolutely vertical, just solidly placed.
Jon
Cocker Spaniels
Palladium
Jun 21, 2011 19:00 as a reply to  @ Jon's post |  #12
a 400mm 2.8 enough said :lol:
Silverstonev8
Joined Jun 2011
Jun 21, 2011 20:04 |  #13
So Im thinking at this point im going to just get the L bracket and the kirk mpa-1.
That should take care of my needs.
Thanks everyone
Chris -- Gear List
Savas ­ K
Jun 21, 2011 20:35 |  #14
Mine is RRS's MH-01 with lever clamp on my main monopod. Watch out on Kirk's MPA-1 for when you want to change orientation of the head. It ain't easy and usually means disassembly. The space into which to place a normal hex wrench to loosen it is too small a space to put the wrench in there. I own the Kirk and have it on my small monopod. Definitely, I prefer RRS's MH-01, but it costs bucks.
GregoryF
Jun 21, 2011 20:43 |  #15
Manfrotto 234-RC. Seems to work for what I need.
6D, 5D, 7Dii, Eos R and too many lenses, flashes and aux. gear to list!:cool:
A simple hobby gone horribily wrong
3,961 views & 0 likes for this thread, 25 members have posted to it.
672 guests, 122 members online
