Thread started 21 Jun 2011 (Tuesday) 22:08
Flash Output InConsistent Among 3 540ez Flashes
xknowonex
Jun 21, 2011 22:08 |  #1
I bought 3 540ez flashes used for my strobist setup. They all work and appear to be in the same condition. However, one of them seems to be not as bright as the other 3.
I tried swapping out batteries and it is the same
the-perfect-exposure.blogspot.com (external link)
https://www.facebook.c​om/ThePerfectExposure (external link)
Curtis ­ N
Master Flasher
Jun 21, 2011 23:39 |  #2
"seems to be not as bright"
How are you measuring/comparing?
Does the motorized zoom on all of them appear to work properly, and are you comparing them all at the same zoom setting? Are they all in manual mode at the same power setting?
xknowonex
Jun 22, 2011 00:09 as a reply to  @ Curtis N's post |  #3
HTTP response: 404 | MIME changed to 'image/png' | Byte size: ZERO
They're at all the settings but I just noticed that the zoom motor one on the dimmer one doesn't work and make noise like the other one.
How much does it cost to repair? Or should I just sell it off as is for parts?
evilr00t
Jun 22, 2011 01:12 as a reply to  @ xknowonex's post |  #4
Wow, that's a mighty difference in power. I'm not sure you can even get a 540ez repaired nowadays, so good luck XD
XTi, 1D3, 2x SB-28, 580EX, 550EX, Tamron 28-75, 50/1.8, "EF" 18-55 II, "EF" 18-55 IS, 85/1.8, 75-300 III USM, 70-200/4L
tacoman1423
Jun 22, 2011 01:18 |  #5
hmmm, by any chance did you get these on craigslist?
Averion Photography (external link)
FLICKR (external link)
Curtis ­ N
Master Flasher
Jun 22, 2011 01:48 |  #6
xknowonex wrote in post #12636663 (external link)
Repair would cost more than it's worth.
Experiment more with it, try different power settings, see if you can figure out what zoom setting it's stuck on. It's probably still useful, just not as versatile. But you need to come to an understanding of its limitations.
1,148 views & 0 likes for this thread, 4 members have posted to it.
2816 guests, 176 members online
