Thread started 16 Oct 2005 (Sunday) 17:50
stupid problem with lens cap
AndrisP
Oct 16, 2005 17:50 |  #1
i have bad habit - i often forget to take off the lens cap when turning on my G6, the lens retracts without a warning signal which as I read in manual should be played.. In manual there was said that lens wouldn't retract if cap is left on.
what to do ?
PS2. sorry for language, if it's bad :).. not my native
AndrisP
Oct 16, 2005 18:01 |  #2
and even more - my lens rings are a bit losy (loosy ?:)) .. just a bit, but i'm worying about that.. the camera is very new (it's about 4 or 5 days old).. is that normal ?
jon1996
Oct 16, 2005 18:14 |  #3
what to do ?
Well, The only time you will here a lens warning will be if you like left it laying on the lens and tried to turn it on, the lens cap alone is not tight enough to make it stall hard enough for the warning sound to come on, I know when I do that which is alot it just pops the cap off for me, and you said yours was loose? They are not the best designed lens cap on the market, they can be knocked off by the smallest bump, I hope this helps,
jon
Canon 20D
18-55 IS, 55-250 IS, 50 1.8,
Panasonic FZ50
Canon G6 with about 40,000 Pics
www.jonsphoto.smugmug.​com (external link)
lefturn99
Oct 16, 2005 20:52 |  #4
I leave my lens hood on all the time. It has it's own adapter and the lens cap fits on it. There is plenty of room for the lens toextend. My only penalty is a black LCD.
6D, 5D Mk III, 60D, EOS M, Gear List
AndrisP
Oct 17, 2005 01:20 as a reply to  @ lefturn99's post |  #5
Thanks for helping, but with "lens rings" i meant those silver rings which makes together lens.. there are two of them - one large and one a bit smaller.. on my camera that small ring is a bit loose, is that normal ?
Mannytkd
Oct 17, 2005 03:11 as a reply to  @ AndrisP's post |  #6
.....i'll answer the lens movement for you, i have a G6 and have a very loose front lens but don't worry about it, it won't make your imeges go funny or wrong. Even with SLR lenses there is a bit of movement, it's normal.
Canon 50D | [COLOR=black]18-55 IS | 55-250 IS | Canon EF 100mm USM macro | Canon 50mm MK2 | Tokina 11-16 | Kenko Auto Extension Tubes | Uniloc 1200 series pod | Canon 430EX flash gun | Some filters
www.karls-photography.co.uk (external link)
AndrisP
Oct 17, 2005 04:02 as a reply to  @ Mannytkd's post |  #7
thanks a lot ;) i can calm down now :)..
1,670 views & 0 likes for this thread, 4 members have posted to it.
2278 guests, 93 members online
