Thread started 22 Jun 2011 (Wednesday) 04:04
Lens with two apertures
raavi
Jun 22, 2011 04:04 |  #1
As you might have experienced that squinting human eye can able to see outside world slightly sharper...
With that, Will adding an another aperture to an existing lens produces any sharper pictures, provided both apertures have same or different opening?
Just curious...
Ross ­ Murray
Joined Nov 2010
Jun 22, 2011 04:26 |  #2
raavi wrote in post #12637429 (external link)
Just curious...
When you're squinting you're just getting a pinhole camera effect. Where a small pencil of rays goes to pretty much the same imaging point (where as when you're not squinting and not corrected for any refractive error you're not getting rays going from a single object point to a single(ish) image point. So all you're doing is really stopping the lens down (if you want to talk in photography terms).
Camera: Canon EOS 1D MkII
Lenses: Canon 50mm f/1.8 II, Canon 50mm f/2.5 Macro, Canon 70-200mm f/2.8L,
Sigma 15-30mm f/3.5-4.5 EX DG, Sigma 400mm f/5.6 APO HSM Telemacro, Tamron SP 90mm F/2.5 Macro
raavi
Jun 22, 2011 04:53 |  #3
Some gentleman has posted this
http://www.the135stf.n​et/index.html (external link)
on an another forum.
Ross Murray wrote in post #12637471 (external link)
pulsar123
Gallery: 82 photos
Jun 22, 2011 08:36 |  #4
I believe some expensive zoom lenses do use two stop apertures inside - perhaps one is used at one FL end, and the other one at the other end. It is also possible that both are used at the same time, to maximize quality in the frame corner.
Regarding "smaller aperture means sharper image": it works only as long as light diffraction around the aperture stop is negligible. Diffraction kicks in around f/5.6-f/8.0 on most lenses, and at smaller apertures you start loosing your resolution.
6D (normal), 6D (full spectrum), Tamron 24-70 f2.8 VC, 135L, 70-200 f4L, 50mm f1.8 STM, Samyang 8mm fisheye, home studio, Fast Stacker
phreeky
Jun 22, 2011 09:03 |  #5
Things get sharper for you when you squint?!?!? Maybe if you're eyes are going, I dunno.
Ross ­ Murray
Joined Nov 2010
Jun 22, 2011 09:16 |  #6
phreeky wrote in post #12638330 (external link)
No he's right, next time your at a shop that sells the ready readers put on a pair of them (more powerful the better) and look at a distant object. If you're an emmetrope it'll be blurred. Now screw up your eyes, you'll see it becomes sharper.
1,083 views & 0 likes for this thread, 4 members have posted to it.
1134 guests, 164 members online
