mr.white wrote in post #12657494
Hey John,
I've gone 9:1 with the mpe and a raynox msn-202 without a macro focusing rail, just takes practice and resting the lens on a steady surface helps. up to 5:1 a good bracing technique can be sufficient.
Cheers,
Paul
For the benefit of those who do NOT have the MP-E 65, this lens does not focus. The only thing this lens does is rotate between 1x- and 5x magnification. Therefore, in order to achieve focus, you must physically move closer to the subject, or farther away from the subject, to achieve your desired focus.
That said, Paul, I have also hand-held at 5:1 and "braced myself" against any manner of objects to try to "hold still enough" to get a decent shot. For that matter, I have also "used a tripod" at 5:1 (and just leaned forward or leaned back to achieve focus) ... but the simple fact is I get my best results when using a tripod and a macro rail, because doing so allows me to let go of the camera and take advantage of live view, mirror lock-up, as well as a remote switch. To me, trying to hand-hold on ultra-close macros is tantamount to trying to take portraiture while operating a jackhammer. You might get the shot, if you're lucky, but it is not exactly "best practice."
Paul, anyone can cut corners and say they've "done so" ... and I have done so too ... but this does not make your experience (or mine!) BEST PRACTICE. It just means that you (as well as I) have cut corners at times and achieved acceptable results.
You know as well as I do that there is no way you can get the same precision focus by hand-holding and squinting, looking through your viewfinder, as you can looking at the subject through Live View, blown-up 10x, to ensure ultra-critical focus. You know as well as I you simply cannot depress the shutter "with your finger" and be as steady as you will by using a tripod, letting go of your camera, and using a remote switch with mirror lock-up. We both know it is simply impossible.
That said, using a macro rail witht he MP-E 65, taking advantage of Live View, mirror lock-up, and a remote switch is simply best practice. This doesn't mean a person "can't" hand-hold and get decent results with a flash at times. But nor should the fact that a person "can do this" in any way fool the reader into thinking that this is best practice.
Going through all of this trouble may not be practical for the field, I fully agree, but I personally don't consider the MP-E 65 much of a "field" lens to begin with. I only use this lens for controlled, staged shots. For me personally, if I am going to hand-hold in the field, the 100mmL macro is what I use (or the 180mm on a tripod, depending upon what it is I am after).
Cheers
Jack
