Thread started 24 Jun 2011 (Friday) 03:31
Amateur Shots: First attempt at shooting the stars!
nebulight
Jun 24, 2011 03:31 |  #1
I've been driving across the country and made a stop in Colorado and pulled on my 50D, 28-135 and tripod. Snapped the following at 30 seconds, F3.5, and ISO3200:
IMAGE: http://i278.photobucket.com/albums/kk109/milesd83/IMG_1873.jpg
IMAGE: http://i278.photobucket.com/albums/kk109/milesd83/IMG_1869.jpg
IMAGE: http://i278.photobucket.com/albums/kk109/milesd83/IMG_1871.jpg
And I took this in Arizona a few nights ago, not sure why it's so blurry:
IMAGE: http://i278.photobucket.com/albums/kk109/milesd83/IMG_1497.png
I'm looking into the possibilities of taking similar photos in PA. If it's possible, I'll be making a few purchases to take better photos.
Mark ­ Brim
Jun 24, 2011 03:43 |  #2
Good effort. you must have some clear skys where you live
5D, 7D, 30D. Sigma 30,50 1.4, Canon 70-200 f4, Sigma 10-20
Flickr: http://www.flickr.com/​photos/markbrim/ (external link)
Blog: http://http …brimacombe.word​press.com/ (external link)
tkerr
Jun 24, 2011 11:06 |  #3
If you want nice round stars you're going to have to shorten your exposures a little.
You're using a 50D, a 1.6 crop body camera with a 28-135mm lens. Use the shortest focal length. And then here is a little formula you might want to keep handy.
1.6 x 28 = 44.8.
IOW that's like using a 44.8mm lens on a FF Body to get the same FOV.
Now divide 500 by 44.8 = 11.16seconds
Or just 500 / 28 = 17.85seconds / 1.6 = 11.16 seconds
or 500 / (28*1.6) = 11.16
That's how long you can shoot with your camera on a stationary tripod without trailing stars. However, You can probably get away with 20 seconds clearly as long as you are only reducing its size for display on the web.
Edited: Made a terrible mistake with the formula and corrected it.:o
Tim Kerr
F1, try it you'll like it.
archer1960
Gallery: 6 photos
Jun 24, 2011 12:18 |  #4
nebulight wrote in post #12649396 (external link)
It's blurry because your subject moved!! :D
Gripped 7D, gripped, full-spectrum modfied T1i (500D), SX50HS, A2E film body, Tamzooka (150-600), Tamron 90mm/2.8 VC (ver 2), Tamron 18-270 VC, Canon FD 100 f/4.0 macro, Canon 24-105 f/4L,Canon EF 200 f/2.8LII, Canon 85 f/1.8, Tamron Adaptall 2 90mmf/2.5 Macro, Tokina 11-16, Canon EX-430 flash, Vivitar DF-383 flash, Astro-Tech AT6RC and Celestron NexStar 102 GT telescopes, various other semi-crappy manual lenses and stuff.
e.pie
Jun 24, 2011 12:26 |  #5
archer1960 wrote in post #12651168 (external link)
Technically the camera moved, now you just need a lens with IS. ;)
5DmkIII | 17-40mm f/4L | 24-105mm f/4L IS | Sigma 120-300mm f/2.8 non-OS w/2x telecon | 35mm f/2 | 40mm f/2.8 | 50mm f/1.8 | 100mm f/2 | ЮПИТЕР-37A |24-85mm f/3.5-4.5 | 580ex | 2x 550ex | bunch of other miscellaneous filters and stuff :p
fullerfotos.net (external link) or click here for my flickr (external link) or here for my 500px (external link)
TheLostVertex
Jun 24, 2011 12:35 |  #6
e.pie wrote in post #12651199 (external link)
Technically, everything is moving ;)
Steven R.
e.pie
Jun 24, 2011 13:03 |  #7
TheLostVertex wrote in post #12651249 (external link)
Touche :lol:
tkerr
Jun 24, 2011 13:21 |  #8
Not when the camera is mounted on a tripod! Which it was, and that lens does have IS. If the IS was turned on while mounted on a tripod, that can cause blur.
However, I suspect that he didn't have a remote switch and was pushing the shutter button which will cause blur also.
Technically it is the Earth that is moving at approximately 1000 mph, at the equator. Additional it is moving around the Sun at about 67,000 mph ;)
See, we're not so slow after-all!
The stars are so distant that any movement among them wouldn't be detected with the naked eye.
Tim Kerr
archer1960
Gallery: 6 photos
Jun 24, 2011 14:01 |  #9
tkerr wrote in post #12651476 (external link)
I think the point was that the camera was moving WITH the earth, not that it was moving RELATIVE to the earth.
You may not be able to detect the *apparent* star motion with the naked eye, but put a long zoom on, and it's easy.
tkerr
Jun 24, 2011 14:52 |  #10
archer1960 wrote in post #12651663 (external link)
You think so!
Is a 1200mm Focal length 10 inch Aperture f/4.7 Telescope long enough? or how about doubling that to 2400mm focal length? ;)
The motion you detect is not the stars moving but rather the motion of the Earth relative to the position of the stars against the night sky. A longer focal length only increases the magnification (narrower FOV) therefore making the motion of the Earth more obvious.
By The Way, I knew what the point was. Thus the ;) in my comment.
Tim Kerr
SteveInNZ
Jun 24, 2011 17:07 |  #11
This is going to be one of "those" threads. :)
tkerr wrote in post #12651862 (external link)
I'm sure you meant the rotation of the Earth rather than its motion through space. ;)
Not that it matters anyway, because the OP asked why they were blurry and that isn't due to the motion. It's blurry because it's out of focus.
Nebulite - Good effort and welcome to the world of astrophotography. That looks like a nice dark spot. Use manual focus and live view on max zoom to focus on a bright star or planet and then recompose if you need to.
Steve.
"Treat every photon with respect" - David Malin.
nebulight
Jun 26, 2011 09:32 |  #12
Yes, I understand the motion of the earth so I knew I was going to get some star trail, however the one last shot was much more blurry than the other three. I did use a tripod with IS disabled and a time release shutter. Could it have position (one in south Arizona, the other in north Colorado?) Could angle be a factor?
And thanks for the info and comments.
Also, could anyone answer my question about PA? Is it possible to get something similar at the lower elevation? Sorry if these are newbie questions, this is my first shot at it so it's ALL new to me.
tkerr
Jun 26, 2011 09:50 |  #13
nebulight wrote in post #12659690 (external link)
Elevation and or latitude have nothing to do with clarity. Other than camera shake or focus, the other things that effect focus are the atmosphere. Either Astronomical Seeing, Transparency or a combination of Both.
Seeing is the stability of the atmosphere, Air and thermal currents throughout different altitudes. And transparency is the amount of moisture throughout the atmosphere. Either or both can make your pictures look blurry.
Refer to this web site to learn more about Seeing and Transparency.
http://cleardarksky.co​m/c/Starfestkey.html?1 (external link)
When I PA, if you find a clear area you should be able to get the shot you are after.
On Edit:
If it is windy and your tripod is not very stable you will also get blurred pictures.
If it is humid, watch for condensation on the lens.
Tim Kerr
archer1960
Gallery: 6 photos
Jun 26, 2011 14:51 |  #14
tkerr wrote in post #12659762 (external link)
Latitude will affect trailing, though. Targets near the poles don't move by as many pixels during a given exposure time as targets near the celestial equator, so if you're shooting straight up (or nearly so), being further south will give you trails sooner than points north.
tkerr
Jun 26, 2011 15:25 |  #15
archer1960 wrote in post #12660844 (external link)
Yes, but that is not why one is blurry and the others not. Latitude will not effect focus / clarity.
Location however will, Especially near the mountains of Arizona and Colorado. Where you are in relationship to the mountains can have serious effects on the Astronomical Seeing. That is if that is the problem and not an unstable tripod or poor focus.
Tim Kerr
4,971 views & 0 likes for this thread, 12 members have posted to it.
872 guests, 140 members online
