So Ive been trying to figure out a good tripod/head combo to go with for video. Right now Im looking at these two setups in the $750 range:
Is there another brand/combo I should be looking at?
Any input is always welcome. Thanks all in advance.
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Jun 24, 2011 17:18 | #1 So Ive been trying to figure out a good tripod/head combo to go with for video. Right now Im looking at these two setups in the $750 range: Is there another brand/combo I should be looking at? Any input is always welcome. Thanks all in advance. [Gear List | Flickr
Chippy569 Goldmember 1,851 posts Likes: 1 Joined Dec 2010 Location: Minneapolis, MN More info | Jun 24, 2011 21:32 | #2 the 540HD is a new head, i'm not seeing it listed on their site yet. The 519 is a bit older, rated up to 10kg (your rig is 4.6kg and after camera and a lens you're probably around 7kg so that's fine, unless you have tons of accessories mounted to it). Because of the foot design it won't be the most friendly to be taking into the wilderness so if you're sticking mostly to indoors or at least decently-flat surfaces you'll be good. (The cross-braces aren't on the bottommost feet, though, so that's a plus.) Gear List
ben_r_ THREAD STARTER -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Jun 25, 2011 09:22 | #3 Im sorry, that was my mistake, its not a 540, its the 504HD. I mis-typed that and fixed it above. That being the case now which head is a better choice? Or should I be looking at another? [Gear List | Flickr
ChannelOne Goldmember 1,951 posts Likes: 204 Joined Nov 2010 Location: Clewiston Florida USA More info | Jun 29, 2011 06:30 | #4 ben_r_ wrote in post #12652502 So Ive been trying to figure out a good tripod/head combo to go with for video. Right now Im looking at these two setups in the $750 range:Same set of legs, two different heads, both kits come with the same carrying bag, same price and Im not sure which would be best to go with. I will be mounted a Redrock Micro Shoulder Rig onto this like this one: LINK Is there another brand/combo I should be looking at? Any input is always welcome. Thanks all in advance. The 504 head is better suited for a light body such as a HDSLR whereas the 519 is designed more for an ENG shoulder mounted camcorder. Do what you love and you will love what you do, that applies to both work and life.
ChannelOne Goldmember 1,951 posts Likes: 204 Joined Nov 2010 Location: Clewiston Florida USA More info | Jun 29, 2011 06:31 | #5 Chippy569 wrote in post #12653426 Because of the foot design it won't be the most friendly to be taking into the wilderness so if you're sticking mostly to indoors or at least decently-flat surfaces you'll be good. Why is that?? Do what you love and you will love what you do, that applies to both work and life.
ben_r_ THREAD STARTER -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Jun 29, 2011 09:16 | #6 Yea thats what I think Im going to end up going with. There is very little out there on the 519 and the 504HD seems to be getting a lot more publicity and from that what I have seen I do really like. I dont see that the 546B legs are amazing by any standards, but Ill probably end up replacing those someday with a set of Gitzo 3 series legs and a bowl adapter or something like that. [Gear List | Flickr
dariusz Member 139 posts Likes: 1 Joined Mar 2007 Location: Dublin , Ireland More info | Jul 23, 2011 22:27 | #7 ben_r_
ben_r_ THREAD STARTER -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Jul 24, 2011 02:06 | #8 Oh yea, Id LOVE a SACHTLER. Not there yet though. I will someday. I went with the 504HD and 546B combo and so far its seems decent enough to get me through until I can get a real video tripod/head setup. [Gear List | Flickr
gibsonla Goldmember 1,009 posts Likes: 1 Joined Oct 2009 More info | Jul 24, 2011 09:48 | #9 I have the 504hd/546b set and I don't think you'll be disappointed at all =) Michael L. Solomon
ben_r_ THREAD STARTER -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Jul 24, 2011 09:52 | #10 Yea it seems to be pretty darn solid and the counter balance works decent enough if you keep the load low. [Gear List | Flickr
ben_r_ THREAD STARTER -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Aug 31, 2011 19:56 | #11 Well that didnt last long... Ended up selling the 546B legs and picking up a set of Gitzo GT3541LS legs with a 75mm bowl adapter. There was nothing wrong with the 546B legs, they were just heavy and slow to setup. That and I have always wanted a 3 series Gitzo to compliment my Gitzo Traveler 1541T/Markins Q3T travel/hiking setup. So this way I have the 3 series doing double duty for photography and videography. [Gear List | Flickr
Mossman6 Senior Member 952 posts Joined Aug 2009 Location: Sacramento, California More info | Aug 31, 2011 20:41 | #12 If your going to spend 700+ then a used sacthler would be a better option. The Manfrotto heads still stick on starts of pans/tilts. Once you try a sachtler and then go play with a manfrotto, you will notice the slight stickiness I'm referring too. My name is Josh. I love FB likes.
ben_r_ THREAD STARTER -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Aug 31, 2011 20:50 | #13 Mossman6 wrote in post #13032971 If your going to spend 700+ then a used sacthler would be a better option. The Manfrotto heads still stick on starts of pans/tilts. Once you try a sachtler and then go play with a manfrotto, you will notice the slight stickiness I'm referring too. You are quite right. Good to see youre still around Josh! Hope youve been well! And yes, Sacthler is on the list. I got a really good deal on the 504HD head and just got it as a starter head. Im intending to sell it when I get the funding for the Sacthler and figure out which Sacthler Im going to go with. Audio is going to be my focus first however. Thats gonna take A LOT of funding for a while though, so the Manfrotto will have to do for the moment... [Gear List | Flickr
Mossman6 Senior Member 952 posts Joined Aug 2009 Location: Sacramento, California More info | Aug 31, 2011 21:42 | #14 ben_r_ wrote in post #13033007 You are quite right. Good to see youre still around Josh! Hope youve been well! And yes, Sacthler is on the list. I got a really good deal on the 504HD head and just got it as a starter head. Im intending to sell it when I get the funding for the Sacthler and figure out which Sacthler Im going to go with. Audio is going to be my focus first however. Thats gonna take A LOT of funding for a while though, so the Manfrotto will have to do for the moment... Heres the tripod setup so far: Yeah still around My name is Josh. I love FB likes.
ben_r_ THREAD STARTER -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Aug 31, 2011 21:55 | #15 Mossman6 wrote in post #13033229 Yeah still around Just staying super busy with business. I used to own bogen heads too and they're about 80% of what the big boys can do. They are very nice heads for the money and I wished that bogen had found a way to make their starts and stops of pans/tilts more solid. When your ready for the Sachtler's give me a call. I used to own them when I filmed weddings. Vinten is another brand to look into. ![]() Alrighty, will do! [Gear List | Flickr
| Latest registered member is semonsters 1080 guests, 114 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
