Received a Markins Q3T ballhead and have a question. How tight should it be to close on the plate? Don't want to damage it. Am using all the same RRS plates. Thanks
D.C. Goldmember 1,156 posts Likes: 10 Joined Apr 2006 Location: Montana More info | Jun 24, 2011 17:39 | #1 Received a Markins Q3T ballhead and have a question. How tight should it be to close on the plate? Don't want to damage it. Am using all the same RRS plates. Thanks Duane
Jun 24, 2011 17:48 | #2 I have an RRS lever clamp and L-plate. It requires a fair amount of force to lock it down. Not so much that your hand hurts or anything, but enough that you know its clamped tightly.
Snydremark my very own Lightrules moment More info | Jun 24, 2011 17:49 | #3 Tight enough that the lever can be flipped all the way closed without forcing it and also not come open easily? I can't think of a good way to explicitly describe since there's not marked gauge or anything. I have the Q20 and it takes a bit of effort to unlatch; using the Markins plates. - Eric S.: My Birds/Wildlife
tvphotog Cream of the Crop More info | Jun 24, 2011 17:59 | #4 Good question. I just experimented with different tensions on the set screw until it seemed to close with thumb pressure, but not to see to have to force it. Jay
Jun 24, 2011 18:31 | #5 tvphotog wrote in post #12652675 Good question. I just experimented with different tensions on the set screw until it seemed to close with thumb pressure, but not to see to have to force it. Of course, I had had the RRS lever release and knew the feel of that one, so I set the Markins to about the same tension. I'm curious, did you replace an RRS head with a Markins? Why?
tvphotog Cream of the Crop More info | Jun 24, 2011 18:35 | #6 Yes, because the RRS I had on a previous travel tripod was too wide at the clamp for my new Feisol 3441t setup. The smaller RRS did not have the same threaded screw as the attachment point on the tripod. The Markins was the same. I've been very happy with the Markins, same quality as the RRS. Jay
Jun 24, 2011 19:09 | #7 I guess I have it about right then. Not so tight as it feels like it will break, but a little difficult. Same combo as you Jay. Thanks for the review. Duane
Jun 25, 2011 08:28 | #8 tvphotog wrote in post #12652809 Yes, because the RRS I had on a previous travel tripod was too wide at the clamp for my new Feisol 3441t setup. The smaller RRS did not have the same threaded screw as the attachment point on the tripod. The Markins was the same. I've been very happy with the Markins, same quality as the RRS. If you look at the first photo in the review, you can see that the Gitzo legs folded under the release clamp; the same RRS on the Feisol would have placed the clamp within the legs, and the clamp would have prevented tight closing of the inverted legs. Thanks! I hadn't seen that review before, it's a good writeup. you've got me thinking...
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Jun 25, 2011 09:12 | #9 mike_d wrote in post #12652631 I have an RRS lever clamp and L-plate. It requires a fair amount of force to lock it down. Not so much that your hand hurts or anything, but enough that you know its clamped tightly. Same here. [Gear List | Flickr
| Latest registered member is semonsters 1464 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
