is there much difference in 16" vs. 22" beauty dish ?
Would larger beauty dish produce more even light ?
picard Goldmember 1,996 posts Likes: 1 Joined Jan 2006 Location: Canada More info | Jun 25, 2011 02:56 | #1 is there much difference in 16" vs. 22" beauty dish ? Canon 1DM4,7D, Rebel XT
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Jun 25, 2011 06:02 | #2 The difference is 6 inches. "If you're not having fun, your pictures will reflect that." - Joe McNally
Farley121 Member 75 posts Joined Dec 2009 More info | Standard opinion says that a beauty dish produces it's specific quality no further away than double it's diameter. So a 16" must be no further than 32" and a 22" no further than 44". That's a huge difference if you are trying to get the light out of the frame. As usual, the bigger the light source, the softer.
clarence Goldmember 2,204 posts Likes: 1 Joined May 2008 Location: Northern VA More info | Jun 25, 2011 11:19 | #4 Curtis N wrote in post #12654742 A 22" light source is 37.5% larger than a 16" light source. 37.5% larger? For Sale: 1D, T1i, 800mm, 600mm
spacetime Goldmember 1,276 posts Joined Oct 2009 More info | Jun 25, 2011 11:37 | #5 clarence wrote in post #12655512 37.5% larger? area of a circle = pi * radius squared 16^2 * 3.14 = 803 sq" 22^2 * 3.14 = 1519 sq" 16" dish x 189% = 22" dish You're using the diameter instead of the radius so you figures aren't entirely correct.
clarence Goldmember 2,204 posts Likes: 1 Joined May 2008 Location: Northern VA More info | Jun 25, 2011 12:06 | #6 yep, you're right. I changed to the radius at r=8 vs r=11 and still get 189% For Sale: 1D, T1i, 800mm, 600mm
Jun 25, 2011 17:37 | #7 sheesh. you guys are too nerdy. Canon 1DM4,7D, Rebel XT
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Jun 25, 2011 18:43 | #8 Shadow quality is related more closely to a light source's linear size than its total area. That's why I compared diameter instead of area. "If you're not having fun, your pictures will reflect that." - Joe McNally
clarence Goldmember 2,204 posts Likes: 1 Joined May 2008 Location: Northern VA More info | Jun 25, 2011 19:19 | #9 Curtis N wrote in post #12657145 Shadow quality is related more closely to a light source's linear size than its total area. That's why I compared diameter instead of area. So a 72"x12" strip light and a 72" PLM umbrella have comparable "shadow quality" since they have identical linear size? For Sale: 1D, T1i, 800mm, 600mm
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Jun 25, 2011 20:20 | #10 clarence wrote in post #12657271 So a 72"x12" strip light and a 72" PLM umbrella have comparable "shadow quality" since they have identical linear size? Depends on what you're lighting, and how the light is positioned. "If you're not having fun, your pictures will reflect that." - Joe McNally
clarence Goldmember 2,204 posts Likes: 1 Joined May 2008 Location: Northern VA More info | Jun 25, 2011 20:25 | #11 I was just interested in learning how/why shadow quality is limited to one-dimension. For Sale: 1D, T1i, 800mm, 600mm
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Jun 25, 2011 20:55 | #12 I didn't say one dimension. "If you're not having fun, your pictures will reflect that." - Joe McNally
| Latest registered member was a spammer, and banned as such! 2908 guests, 178 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
