Thread started 17 Oct 2005 (Monday) 12:48
new canon ef 70-300 is usm
gtdds
Oct 17, 2005 12:48 |  #1
does anyone know what are the best settings to shoot outdoor soccer? i used this lens for the first time over the weekend on mode 2 IS and was not happy with the results. i think the problem is with me so if anyone knows the best settings i would be most grateful. thanks
Andy_T
Joined Jan 2003
Oct 17, 2005 13:29 |  #2
f/8
1/500
pray for lots of sunshine....
(sorry, couldn't resist :wink: . I don't really knoow the lens. But I think the f/8 will be helpful with it, according to all I've heard)
Best regards,
Andy
some cameras, some lenses,
and still a lot of things to learn...
(so post processing examples on my images are welcome :D)
If you like the forum, vote for it where it really counts!
CLICK here for the EOS FAQ
CLICK here for the Post Processing FAQ
CLICK here to understand a bit more about BOKEH
ttmatsu
Joined Jun 2005
Oct 29, 2005 19:52 |  #3
As Andy stated, put your camera into aperature priority, set it for f8 and try for a minimum shutter speed of 750 by changing the ISO setting. Then turn off IS. Make sure that you have the focus set to AI Servo with only center focus point active. If you set your camera to Program or green or sports mode, it will pick the biggest aperature (lowest fstop) possible while keeping other parameters reasonable. So most likely, it is picking f5.6 for your setup. For most consumer grade lenses, you are safest or most likely to produce good results when you add two stops to the biggest aperature for your lens.
After you shoot and you are reviewing, check your focus point - until you get used to tracking and keeping an erratically moving object in the focus point, you'll see that a lot of out of focus shots are because you just missed having the subject in the focus point.
You didn't state what your dissatisfaction with the pictures was. The zoom is known to be soft on the long end so were your shots mostly in the 250-300 range? Were the players faces in shadow (this is where a L lens helps)? I see a lot of photographers not pay any attention to their positioning in relation to the sun and they wonder why their shots didn't come out well. All it would have taken was a walk to the other side of the field or another end and they would have increased their success rate tremendously.
There are times when you will have to boost your ISO to 800 or 1600 to get the shutter speed you need. Then you will need something like NeatImage or Noise Ninja to take the noise out. It is a sad fact of digital photography - especially when dealing with lenses that don't have "pro" quality optics (there are some reasonably priced lenses with good optics) that some skill in post processing is required to render good results. Something people don't realize is that film processing incorporates a lot of computerized processing that "fix" picures automatically. With digital, you are now doing the automated process that has been incorporated into processing film into prints.
Good luck.
ghocking
Oct 30, 2005 06:14 |  #4
Outdoor soccer?, never heard of it. Is it a bit like football or a new US game.
Please Please Please its Football. If I called it soccer at Anfield they would kill me.
Geoff Hocking
G9|20D|40D|50D|5D|7D|1​DMkIIN
60 Macro|50 1.4|100 Macro|17-40 L|24-105 L|100-400 L|Sigma 18-200 OS
270EX|430EXII|580EX
1,299 views & 0 likes for this thread, 4 members have posted to it.
1218 guests, 124 members online
