Thread started 28 Jun 2011 (Tuesday) 23:17
question about 3rd party speed rings for Elinchrom?
picard
Jun 28, 2011 23:17 |  #1
I have question about 3rd party Elinchrom speed rings.
Why don't these rings have screws to tighten the metal rods?
How am I suppose to attach metal rods to other softboxes ?
Canon 1DM4,7D, Rebel XT
580 EX II, 430 EX II
Canon 70-200mm IS II L , Canon 85mm F1.2 L II, Canon macro 100mm F/2.8, 18-55mm kit
Sigma 18-200mm F/3.5-5.6, Sigma 10-22mm, Sigma 50mm F/1.4
Sigma 24-70mm F/2.8 EX DG HSM
Csae
Jun 28, 2011 23:22 |  #2
Theres two components to normal speedrings.
An outer metal ring that has holes for the soft-boxes metal rods to slip inside of, and an inner ring thats specific to each brand of flash that fits into the Flash head itself.
When you mention elinchrom specific speedrings, you are talking only about the inner metal ring that fits to the flash, with no connection to the softboxe's metal rods.
The only execption are the rotalux types which feature a different sort of speedring entirely made for elinchrom and are made to help set-up modifiers like umbrellas, or nearly like anyways.
As it is, your question is not specific enough to be able to help you in any way, i hope my clarification helps you to narrow down your exact problem.
Feel free to call me Case.
CasePhoto.ca (external link) - FanPage (external link)
-Montreal based Photography.
picard
Jun 29, 2011 08:29 |  #3
Csae wrote in post #12674961 (external link)
I want the Cheetah speedring for its beauty dish. how can the speed ring be secured to the dish ?
TMR ­ Design
Joined Feb 2006
Jun 29, 2011 08:41 |  #4
picard wrote in post #12676369 (external link)
Unless you're using the Speed Pro bracket, you don't use a speed ring for the beauty dish. The dish requires an insert (speed ring insert) to be mounted to the back, flat side. The insert is the component that has the actual Elinchrom bayonet.
Robert
735 views & 0 likes for this thread, 3 members have posted to it.
2768 guests, 174 members online
