Thread started 29 Jun 2011 (Wednesday) 20:33
Sleep Mode?
skinnaa
Jun 29, 2011 20:33 |  #1
Hi guys, just looking for a little insight on turning off my Sleep Mode so I can trigger some receivers. I recently inquired about this product (http://cgi.ebay.com.au …&ssPageName=STR​K:MEWAX:IT (external link)) for my Canon 60D + Nissin Di622, I asked the seller if the product will work with my equipment and this is the reply I got..
Hi,
I read some forum and people says that Nissin Di622
doesn't have wake
up function. therefore, if you need to use it with RF-602
you need to
turn off the sleep mode of your flash
Any feedback is much appreciated, thanks guys :)
Facebook Page (external link)
500px (external link)
skinnaa
Jun 29, 2011 21:30 |  #2
Anyone?
Curtis ­ N
Master Flasher
Jun 29, 2011 21:36 |  #3
On the hotshoe, with all six electrical contacts communicating with the flash, you can "wake it up" with a half-press of the shutter button.
The RF-602 receivers have contacts that don't appear to be the same layout as Canon. That doesn't matter, because the transmitter has only the single contact which fires the flash. There's no way you can wake up the flash with it.
Some of the Canon flash units have a custom function to disable the sleep mode, essentially keeping them "awake" until the batteries die. This solves the problem, but I do not know if the Nissin Di622 has such a feature.
TheBurningCrown
Jun 29, 2011 21:38 |  #4
http://www.nissindigit​al.com/en/Di622.html (external link)
With the flash unit set for slave mode, sleep mode is cancelled and the unit will not automatically turn off until 60 minutes have elapsed.
No idea if the hotshoe will work, however.
-Dave
Gear List & Feedback
skinnaa
Jun 29, 2011 22:48 |  #5
Curtis N wrote in post #12680334 (external link)
Energy saving system
The Di622 has a dual energy saving system.
It automatically enters sleep mode when it's not in use for 5 min., and is reset with a touch of the shutter button or any button of the flash.
If the unit is not in use for 30 minutes, it will automatically power off.
skinnaa
Jun 29, 2011 23:19 |  #6
TheBurningCrown wrote in post #12680341 (external link)
Hrmm, ok... well I need to find out if it will, if it does work.. Then I should be alright
skinnaa
Jun 30, 2011 00:43 |  #7
Can someone tell me how to activate slave mode on my Nissin Di622?
TheBurningCrown
Jun 30, 2011 00:44 |  #8
skinnaa wrote in post #12680787 (external link)
Put it on slave mode, put it on the camera, and fire a shot. There's your answer right there.
Otherwise just buy a different flash to use off-camera.
-Dave
skinnaa
Jun 30, 2011 01:12 |  #9
I read this on the internet..
If you have multiple Nissin units, you can place one as your main light and place other units as rim lights. However, they will all have identical exposures so you can’t set one as a subtle fill while the other as a main, for example.
Is there a way to set different exposures from the different Nissin units??
TheBurningCrown
Jun 30, 2011 01:35 |  #10
skinnaa wrote in post #12681171 (external link)
...you just answered your own question.
-Dave
skinnaa
Jun 30, 2011 10:10 |  #11
TheBurningCrown wrote in post #12681223 (external link)
So you can't change the exposure on each individual flash?
HughR
Jun 30, 2011 11:55 |  #12
You have a 60D, so you can wirelessly control A and B flash groups using the pop-up flash, but you need Canon wireless compatible units to do so. The 430EX & 430EX II, 580 series, and 320EX all work fine. I don't know about Nissin units, however.
The 60D wireless does work extremely well under the conditions specified by Canon.
Hugh
Canon 60D, Original Digital Rebel (2003)
EFS 15-85mm IS USM, EF 70-300mm IS USM, Tokina 11-16mm
Speedlite 430EX, Speedlite 430EX II,
Qbox 16 pro, Lastolite EZbox 24x24, Lumiquest Softbox III
3,016 views & 0 likes for this thread, 4 members have posted to it.
Sleep Mode?
2768 guests, 174 members online
