Can someone tell me how to activate slave mode on my Nissin Di622? (using canon 60d)
skinnaa Member 215 posts Joined Oct 2010 Location: Melbourne More info | Jun 30, 2011 00:44 | #1 Can someone tell me how to activate slave mode on my Nissin Di622? (using canon 60d)
msowsun "approx 8mm" More info | Jun 30, 2011 08:45 | #2 skinnaa wrote in post #12681071 Can someone tell me how to activate slave mode on my Nissin Di622? (using canon 60d) The Nissin Di622 is not compatible with the Canon wireless system built into your 60D. The Nissin Di866 and the newer Di622 II are compatible. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
Jun 30, 2011 10:08 | #3 msowsun wrote in post #12682250 The Nissin Di622 is not compatible with the Canon wireless system built into your 60D. The Nissin Di866 and the newer Di622 II are compatible. BUT..... these flashes do have a built in optical slave which will work with ANY ETTL flash. All you need to do is turn on the optical slave function of your Di622 and make sure it is in manual mode. Also, make sure your 60D flash is set to ETTL. The Di622 is programmed to respond to the main flash after it see the ETTL preflash. (if the 60D flash is set to manual, there will be no ETTL preflash and the Di622 will not fire properly) Oh, I have the MK II
msowsun "approx 8mm" More info | Jun 30, 2011 10:38 | #4 I guess the manual will tell you how to set it up then. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
dedsen Goldmember 2,580 posts Likes: 34 Joined Aug 2006 More info | Jun 30, 2011 12:36 | #5 Here is a good review of your flash that touches on the wireless capabilities. Maye that will help.
| Latest registered member was a spammer, and banned as such! 2768 guests, 174 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
