When they talk about a 1:1 ratio they say that means true to size 1cm = 1cm right?
But the pictures come out to be way bigger then real life. I mean I don't have a true macro... I use extension tubes and therefore not anywhere as good as a true macro. I took a pic of ants and they were waaay bigger then true life size.
But I guess that is the question, 1:1 viewed how? at the native ratio of your pixel ratio?
Wouldn't say a 100mm 2.8 macro taken with a 10 mp camera at a 3888x2592 pixel ratio, or taken with an 18mp with a 5760 x 3240 pixel ratio..... have a different macro ratio?
Then there is full frame and crop sensors, they change the size of the ratio right? an 18mp full frame sensor ,would change the size compared to an 18mp crop sensor. You could use the same situation from above and get different pictures, therefore a different size with the same lens , at the same distance..... but still with the same amount of pixels
So where are they getting the ratio from? what is the benchmark? The standard of which they take their calculations from?
