I use that Stroboframe camera flip bracket also.
1. I like a camera flip vs. a flash flip because when I am bouncing a flash using a reflector/diffuser, I need to adjust the flash every time I switch from vhorizontal to vertical because the flash is pointing in the wrong direction. (note: This is camera flip bracket in both illustrations but, I have used it as a flash flip to illustrate the problems flipping the flash)
IMAGE LINK: http://rpcrowe.smugmug.com …H#1304495185_BDsrRmW-A-LB
IMAGE LINK: http://rpcrowe.smugmug.com …H#1304495186_V99r5dH-A-LB
2. I went from a flash-flip bracket to a generic Chinese knock-off camera-flip bracket which worked OK. What I didn't like about this bracket is that the bar which supports the flash also flips. This made carrying the rig using the bar as a handle difficult. (this is the rig I used for the two illustrations)
3. I now use an OEM Stroboframe camera flip bracket just like the one in the B&H link. I bought it for $14 USD used on eBay. It works great, the camera flip mechanism is smoother than on the Chinese Knock-Off and the flash bar is solid giving me a great handle.
IMO, the flash bracket using bounced flash (in my case a 550EX) and modified with a Joe Demb Flash Diffuser Pro
www.dembflashproducts.com
provides great lighting, is easy to use, and doesn't cost a king's ransom.
IMAGE LINK: http://rpcrowe.smugmug.com …LJM#1244320241_7kTXJ-A-LB
IMAGE LINK: http://rpcrowe.smugmug.com …LJM#1244551055_ox8GE-A-LB
IMAGE LINK: http://rpcrowe.smugmug.com …LJM#1245211231_aEf5x-A-LB
