I currently use the canon 100mm-400mm but i find myself using it mostly at the 400mm end, would i see a good deal of improvment with the 400mm f5.6 prime.
Thanks all
theduck Member 67 posts Joined Jun 2009 More info | Jul 01, 2011 21:09 | #1 I currently use the canon 100mm-400mm but i find myself using it mostly at the 400mm end, would i see a good deal of improvment with the 400mm f5.6 prime.
woos Goldmember 2,224 posts Likes: 24 Joined Dec 2008 Location: a giant bucket More info | Jul 01, 2011 22:45 | #2 Not really, imho. lol. You'd get faster auto focus, but that's about it. Oh, and nicer size. Stick with the zoom unless you really have a specific need for the super fast AF (course on the 400 5.6 it comes with its own problems like annoyingly huge minimum focus distance). amanathia.zenfolio.com
phreeky Goldmember 3,515 posts Likes: 15 Joined Oct 2007 Location: Australia More info | Jul 01, 2011 23:11 | #3 Depends on what you're after and what your copy of the 100-400 is like.
LBaldwin Goldmember 4,490 posts Likes: 4 Joined Mar 2006 Location: San Jose,CA More info | Jul 01, 2011 23:16 | #4 The two lenses are not really the same. The zoom offers better range, the tele is sharper at all apertures. The tele is lighter and easier to carry, the zoom is a PITA unless you like push pull glass. Les Baldwin
Jul 02, 2011 06:09 | #5 PITA?.....that seems to be the general advice, not worth adding the prime to my lenes. thanks everyone.
Docsknotinn Member 152 posts Joined May 2007 Location: USA More info | Jul 02, 2011 06:44 | #6 I'd never give up the flexibility of the 100-400 for the prime. I never found the AF on the prime to be enough to call it an added benefit. I do agree there are times when the push/pull has it's draw backs but it's hard to complain about that much glass for the $$$.
Jul 02, 2011 06:52 | #7 Dont get me wrong, i love the 100-400, had it about two years now and wouldn't swap it, even like the push/pull....i was thinking about adding the 400mm prime if there was enough benifit.
sfinkernagel Senior Member More info | Jul 02, 2011 07:53 | #8 I was faced with the decision of which to buy a few years ago- I shoot mostly sports, and did not (do not now either) have the budget for a 2.8. I ended up with the 400 prime, and have never regretted it. This page http://www.luminous-landscape.com …enses/forgotten-400.shtml
Docsknotinn Member 152 posts Joined May 2007 Location: USA More info | Jul 02, 2011 08:01 | #9 I would not consider that a very good comparison considering it was written 9 years ago and the 100-400 has improved considerably since then. There are date codes to note if you are buying used. The IQ on the 100-400 is virtually identical to the prime.
Bazz8 Senior Member More info | Jul 02, 2011 08:13 | #10 theduck wrote in post #12692636 Dont get me wrong, i love the 100-400, had it about two years now and wouldn't swap it, even like the push/pull....i was thinking about adding the 400mm prime if there was enough benifit. I bought the 400mm prime for 2 reasons, 1 as already stated speed, check this site out with comparisons Gear List : SLR BODIES: Eos 5, Eos 3, D30 ( GIFT TO SON INLAW) 40D( SOLD) 1DMK3 ( Current Body)
Jul 02, 2011 08:37 | #11 I tried a 100-400 yesterday, I guess I could get used to that push/pull thing but it would take some time.
phreeky Goldmember 3,515 posts Likes: 15 Joined Oct 2007 Location: Australia More info | Jul 02, 2011 08:38 | #12 Docsknotinn wrote in post #12692760 I would not consider that a very good comparison considering it was written 9 years ago and the 100-400 has improved considerably since then. There are date codes to note if you are buying used. The IQ on the 100-400 is virtually identical to the prime. It does appear that older 100-400 were much softer than the newer, but it's a much more complex design overall and probably much more likely to have soft copies.
peter10 Junior Member 21 posts Joined Aug 2007 More info | Jul 02, 2011 08:49 | #13 I have the 400 prime and I love it, it is so easy to use and get great pictures.
nightcat Goldmember 4,533 posts Likes: 28 Joined Aug 2008 More info | Jul 02, 2011 09:39 | #14 For the slight advantage in image quality the prime has over the zoom, I don't think its necessary to purchase the prime if you already own the zoom and plan on keeping it. Phreeky makes a good point when he says... "Depends on what you're after and what your copy of the 100-400 is like". There seems to be a variance in the quality of the zoom from copy to copy. If you have a good copy, I don't think you need the prime. Personally, I own the prime and love it. With a bit of creativity, its not difficult to hand hold despite not having IS.
Jul 02, 2011 09:58 | #15 Search your topic, this thread comes up at least once every two weeks.
| Latest registered member is NekoZ8 1042 guests, 105 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
