Part 2 of my review is all about the numbers, and of course the big question is...
"How many pops will I get with my _______________ strobes?"
In addition to results released by Innovatronix, I wanted to independently test the Mini with a variety of strobes ranging in power, some that are bi-voltage and one that has analog controls.
The strobes I had for testing were a combination of those I own plus those contributed by Peter (Petepix), David (dmward) and George (george m w).
It's a great selection of some of the most common strobes and those that are most asked about when it comes to portable batteries for location lighting.
Testing was done with the following strobes (listed in order of highest to lowest Watt second rating):
• PCB Einstein E640 (640 Watt seconds/bi-voltage/digital)
• Elinchrom 600RX (600 Watt seconds/digital)
• Elinchrom BX500Ri (500 Watt seconds/bi-voltage/digital)
• Elinchrom D-Lite 4it (400 Watt seconds/bi-voltage/digital)
• PCB Alien Bees B800 (320 Watt seconds/analog)
• Elinchrom 300RX (300 Watt seconds/digital)
• Elinchrom BX250Ri (250 Watt seconds/bi-voltage/digital)
The table below is pretty straight forward. The left hand column has the make and model of the strobe. To the right of that is the Watt second rating.
I tested at Full power, 1/2 power and 1/4 power to give a good overview of performance at different power levels and to be consistent with the way Innovatronix is presenting results for battery life.
Within each power level I've broken it into three parts. The green number on the left is the number of pops achieved from Full charge to the point where the inverter switches to Low battery mode. In red is the number of additional pops while in Low battery mode, and on the right and in bold is the total number of pops for that strobe at that power level.
After the individual lights, I tested the two pairs of strobes I had to show that you could power a pair of 600 or 640 Watt second strobes but it's not really want you want to be doing.... at least not at full power.
Ideally, small portable batteries like this are best suited for a single strobe or a pair of medium powered strobes. If you're planning on going out with 1200 Watt seconds of power then you really want to mate it with a more powerful battery.
On to the numbers....
![]() | HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by FLICKR |
I did not perform these tests multiple times and the numbers are not averages, so results will vary, plus or minus, by small amounts.
These portable batteries are not intended for continuous draw but in a pinch they can be used as long as you stay within the maximum wattage limitation of 400 Watts. Devices that draw continuously will deplete the battery very quickly so it's not something you want to do unless you have to or have a Mini dedicated to that device.
For instance, modeling lights. I didn't test every strobe but I did test the 150 Watt halogen modeling light in my Elinchrom 600RX at full power. I got almost 20 minutes but that was without popping the flash at all. If you used that sparingly in very short amounts of time then it wouldn't be terrible but it's pretty obvious that you don't want to turn on your modeling lights unless absolutely necessary.
The same is true of a portable fan but with fans it's not so bad. If I was to use the King Of Fans 20" fan on high that draws about 156 Watts and lasts about 17 minutes. If you're familiar with that fan, using it on high is like standing next to a DC-10 engine. On the low setting the draw is about 114 Watts and the battery life increases to 29 minutes. Again, if this was a dedicated battery and the fan was being turned on and off as needed then it's not so bad but you wouldn't want to have a fan running all the time and you certainly wouldn't want to have a fan and strobe plugged in to the same Mini.
Going one step further, a more practical portable fan for location work is the Vornado 630. On high it only draws 51 Watts and you can get an impressive one hour of continuous draw.
For those that want to dig a little more into the numbers, I plugged each strobe into the Kill A Watt device to measure the draw (in Watts) when a strobe was on and idling and then how much power it drew when recycling.
I can't vouch for the accuracy of the Kill A Watt, but if nothing else, it's a good reference and way to compare the various power supplies and Watt second ratings.
This table is showing the draw in Watts measured by the Kill A Watt.
Hopefully these results will be of some help.
If you missed Part 1, it can be found HERE.
