Thread started 02 Jul 2011 (Saturday) 17:32
broken 100-400 what to do, fix or new lens?
SpinningCone
Jul 02, 2011 17:32 |  #1
bout a year ago i dove in and bought my first "L" lens. the canon 100-400.
it seemed well built had pretty good quality and was the pride of my lineup and completed my basic set (canon 10-22, canon 17-55 2.8, canon 100 macro, canon 100-400)
unfortunately it appears to not be built all that well and no longer focuses. when i turn the focus ring the focus distance indicator doesn't move, or moves only a little requiring many full rotations to go from close to infinity.
so now i'm wondering what to do. should i sell my 100-400 and get a cheaper lens? a friend of mine bought the 70-300 IS USM and it's almost as sharp as my L lens 300 tons lighter better IS and half the price. but it feels cheap and the front element rotates with focusing so filters are a pain to use
then there's the part of me that thinks that i should sell it and get putt he money towards the 70-200 MK II. i have heard that with a 2x converter that it is about as fast and about the same quality as the 100-400 making it a 140-400 with better IS. though i am unsure if i can still autofocus with the 2x and my XSi (or the 60d which i am hoping to upgrade to) not to mention the additional cost for such a lens
or i can fix my current one, i think the quality is good, and it was cool that all my main lenses ere 77mm filters so i could easily trade caps and filters. the only thing i hate is that it's so heavy and the IS is weak. however I don't know how much it will cost, i don't want to put $500 into it (or spend $60 shipping it back and forth for an estimate). i think i'd rater putt hat towards the 70-200
i need a telephoto to fill out my mm range but am unsure what would be the best option at this point.
any suggestions?
thestone11
Joined May 2011
Jul 02, 2011 17:36 |  #2
Should send it to canon service center and let them check the lens first! No one is going to buy a broken lens anyways, unless it is dirt cheap!
Canon 5D MK II | Fuji X100 | Canon T2i | Canon 100mm macro f/2.8 | Canon 135L f/2 | Canon 50mm f/1.2 L | 17-40mm f/4 L | 24-70mm f/2.8 L | 70-200mm f/4 L IS USM |Canon 430EX II Flash X2 | Pocketwizard TT5 & TT1
JuliusUpNorth
Jul 02, 2011 17:39 |  #3
I like my 100-400 a lot, and if I were in your position, I would send it in for a cost estimate. But only you can decide what you want to do after that. I don't think I would be happy with the 70-200 instead, but that is only my own bias. I had the 70-300 (old version) and found it was never long enough for my work. What do you mostly shoot? Will the 70-200 with a teleconverter be flexible enough?
Good luck, whichever way you proceed!
Julius
98 ­ SNAKE ­ EATER
Jul 02, 2011 17:40 as a reply to  @ thestone11's post |  #4
Either send it in for repair or sell it to me cheap ;)
S.Horton
Jul 02, 2011 17:41 |  #5
Get it fixed if only because you will have to to sell it. I have had no repair over $125 total, including a dropped lens and a 100-400 which needed a new part.
As for the 70-300, I owned that. It is not on the level of the 100-400 and lacks the reach. That said, it was a fine lens for the money, no doubt.
I shoot LAX with a lady who went with the 2X TC and the 70-200 II so I get to see what she produces all the time. It is ok, but just ok. A 2X will surely cost you IQ. 1.4x, not so much.
Sam - TF Says Ishmael
:cool:
GregoryF
Jul 02, 2011 17:44 |  #6
thestone11 wrote in post #12694740 (external link)
I agree 100%. Send it in. If you are looking for a 70-300 at a lower cost than the Canon 70-300 is and one that has better IQ, ftm, non rotating front element check out the Tamron 70-300mm VC USD. Fix your 100-400 and sell it, then buy yourself your 60d!
6D, 5D, 7Dii, Eos R and too many lenses, flashes and aux. gear to list!:cool:
A simple hobby gone horribily wrong
CountryBoy
"Tired of Goldmember label"
Jul 02, 2011 17:48 |  #7
Did you drop it ?
Hi
MOkoFOko
nut impotent and avoiding Geoff
Joined Jun 2010
Jul 02, 2011 17:52 |  #8
S.Horton wrote in post #12694766 (external link)
I owned the 70300 is usm and 100400 at the same time... and there's no way the 70300 is anywhere near as sharp unless he got a really, really soft copy of the 100400. The 100-400 really is one of the ultimate travel birding lenses. The 70300, I'm really sorry to say, is not very good, even relative to its $700 price.
My Gearlist
phreeky
Jul 02, 2011 18:19 |  #9
Sometimes USM lenses do that (insufficient friction in the USM unit or something apparently). I've had a lens do that and have seen others. Luckily mine was under warranty so am not sure what the normal cost is, but they "replaced USM unit".
I would get it fixed. When you get it back then decide whether to sell it or keep it. If you like a smaller/lighter lens then you could downgrade to a Tamron 70-300 VC, for example, and the left over $$ will probably get you a nice small light prime or something else (or just bank the difference).
monty28428
Jul 02, 2011 18:25 |  #10
Note to self -- do not buy a 100-400 from SpinningCone...
GregoryF
Jul 02, 2011 18:38 |  #11
monty28428 wrote in post #12694908 (external link)
bw!:D
macroimage
Jul 02, 2011 18:59 |  #12
The 100-400 came out in 1998 before this press release in 2001:
http://photo.net …topic_id=23&msg​_id=001N3n (external link)
Probably it has a "less than 20 hour" lifespan motor. Buying SpinningCone's use lens after he has it repaired might be a very good deal as it would have a fresh motor rather than an unknown one.
Photo Gear
DreDaze
Gallery: 49 photos
Jul 02, 2011 19:08 |  #13
send it in...even if you were going to try and sell it, it'll help to know how much it's going to cost to repair...you'll get hardly anything for selling a broken lens without knowing what's wrong with it...i bet it's not too expensive of a fix...certainly cheaper than getting a lens of equal length/quality...
Andre or Dre
gear list
Instagram (external link)
SpinningCone
Jul 02, 2011 19:58 |  #14
my friend might just have a good 70-300 or maybe my 100-400 isnt that great. the ID is better but not $700 better, oh and to answer i didnt drop it, took good care of it just stopped working.
i shoot everything and anything. i do people, birds (when i can) landscapes macro buildings etc. i pretty much never go out without all 4 lenses which give me 10-400mm range + 1:1 macro
i like having up to 400mm but i think i could probably get by with 200 for most things. and reviews like this one http://www.ophrysphoto​graphy.co.uk/pages/tut​orial_lenstests1.htm (external link) lead me to believe that i would be gaining IQ at the short end and loosing nothing at the long end.
i wasn't unhappy with the 100-400 but it is a beast to use. the IS is noticeably worse than even my kit lens. i got some decent ones with the 70-300 at 1/25 and 1/50 something i could never get with my 100-400.
i might look into the tamron. i used to have the 18-270 which was pretty good but the build quality wasn't the same as canon, i've considered the newer sigma 50-500 as well.
part of the issue isnt jsut cost but time. with the Tsunami i heard repairs were delayed. i dont want to be without a longer lens for a huge amount of time.
runninmann
what the heck do I know?
Gallery: 47 photos
Joined Feb 2006
Jul 02, 2011 20:40 |  #15
SpinningCone wrote in post #12694717 (external link)
bout a year ago ....
Is it less than a year so that it's still under warranty?
9,408 views & 0 likes for this thread, 14 members have posted to it and it is followed by 2 members.
1156 guests, 168 members online
