Is this something that Canon fixes for no charge? I have a 5dc and after the shuttle launch I wouldn't mind bringing it in to have that done if it's free. I've got a backup to tithe me over until then. How do you know if it's already been done?
j-dogg Goldmember 1,292 posts Likes: 8 Joined Apr 2011 More info | Jul 03, 2011 02:33 | #1 Is this something that Canon fixes for no charge? I have a 5dc and after the shuttle launch I wouldn't mind bringing it in to have that done if it's free. I've got a backup to tithe me over until then. How do you know if it's already been done? 5D / 400d / 70-200-4LIS / 50 Mk.I / 28-70
y2k_o__o Member 38 posts Joined May 2011 More info | Jul 03, 2011 05:22 | #2 register it on canon official website Canon EOS 5D Classic
2011_RBG Member 32 posts Joined Jun 2011 More info | Jul 03, 2011 05:25 | #3 My mirror popped up after a sensor clean just like that. Recommend you get it fixed asap. They will do it free of charge if your shutter count hasnt exceeded 100,000
Okay then, I'll get it taken care of after this Shuttle launch. I've probably got about 9k on it, low miles. Is it also possible to get a shutter count from them while they have it? 5D / 400d / 70-200-4LIS / 50 Mk.I / 28-70
sandpiper Cream of the Crop More info | J-dogg, whereabouts are you based? With a question like this (and many others) the answer depends on where you live and where the camera came from.
JohnB57 Goldmember 1,511 posts Likes: 23 Joined Jul 2010 Location: Holmfirth, Yorkshire, England More info | Jul 03, 2011 07:51 | #6 sandpiper wrote in post #12696782 The free fix is not available worldwide, it isn't available here in the UK for instance (because we don't need it) and I suspect that much of Europe will be the same. Why is this? Canon Europe has the same 2009 announcement on their website as on the US version - http://cpn.canon-europe.com …s/eos_5d_mirror_repair.do
sandpiper Cream of the Crop More info | Jul 03, 2011 09:00 | #7 JohnB57 wrote in post #12696903 Why is this? Canon Europe has the same 2009 announcement on their website as on the US version - http://cpn.canon-europe.com …s/eos_5d_mirror_repair.do I'm not affected by this, just curious why we don't need it... Because the mirror issue only occurs if the camera is used for extensive periods in hot and humid climates, not cold and wet ones like here in Blighty. As our climate is not going to cause the problem to occur, Canon UK has (quite rightly in my opinion) decided not to spend a fairly large amount of money recalling and 'fixing' a large number of cameras that aren't faulty and aren't likely to become faulty.
JohnB57 Goldmember 1,511 posts Likes: 23 Joined Jul 2010 Location: Holmfirth, Yorkshire, England More info | Jul 03, 2011 09:12 | #8 The Canon website is ambiguous then as it appears to offer free repair only for affected cameras - suggesting that the mirror needs to be detached before they fix it (or how would you know it was affected?) Other parts of Europe can of course be both hot and humid.
Mark_48 Goldmember 2,068 posts Joined Nov 2004 Location: Brookfield, MA More info | It's easy to ask a question about a Canon camera fix/repair on this forum, but usually there's a variety of answers depending on where the world the answer comes from. In the end you're going to call Canon anyhow, why not do it in the first place and get the correct information for where you live. It was a free fix for where I live (US) and I believe it was determined by the serial number of the camera. Turn around was fairly quick, around two weeks if I remember correctly. They also replaced and returned the original focus screen, which I'm guessing they may have damaged in the repair. The mirror had not detached prior to sending it in. Megapixels and high ISO are a digital photographers heroin. Once you have a little, you just want more and more. It doesn't stop until your bank account is run dry.
I live in Central Florida, so I more than qualify for the hot and humid envrionment. 5D / 400d / 70-200-4LIS / 50 Mk.I / 28-70
| Latest registered member is semonsters 1688 guests, 140 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
