I recently started to to venture into the off-camera lighting world with Canon Speedlites.
Initially, against many people's advice from veterans on here and elsewhere (yes, Sean, you were right on this), I purchased a 2 sets of Cactus V5 triggers (4 receivers/transceivers total) for $140 bucks total. Not a bad price at all compared to a set of (4) PocketWizards FlexTT5 with a hotshoe ($230 retail x 4 = $920). I figured, if one stopped working, I would just buy a new one for how cheap they are.
I went out on a paid shoot at an event and spent literally half day fumbling around with them since they misfired due to heat on a 95f day. Everytime, I shot through the viewfinder, I had to ask my assistant if they fired up. It wasn't just an issue with one trigger but all four. Worst, by noon, they refuse to power up in the heat but they work fine flawless at home or dusk when its cool 200 feet away.
Needless to say, after corresponding back and forth with the manufacturer, they considered the units defective and offered to send out a replacement if I send my sets back to Hong Kong. I didn't want to risk it and said, "No thanks", and sent it back for a refund for $20 International First Class Mail. In the end, it costed me almost $40 + misery and headache.
So after this whole debacle, I went out to look for a different set. Here are some of the options that I considered
(a) AlienBee CyberSync -
Pros: Bulletproof reliability. Reasonably Priced. Reputable Brand. Holds Value
Cons: Does not use a hotshoe. I do mainly photojournalism so Having a hotshoe on both the transceivers and receivers is important to me because I do use an on-camera flash a lot too. So the ability to throw have an ETTL flash on my camera is pretty important. And most of my older Speedlights do not have a PC Sync port so just sliding a flash onto the hotshoe of the receiver is a major convenience for me.
(a) Pocket Wizard Plus II -
Cons: Same limitations as the CyberSyncs above.
(c) Phottix Strato II -
http://www.phottix.com …reless-flash-trigger.html![]()
http://flashraw.com …i-wireless-flash-trigger/![]()
Pros: Reasonably Priced. Transceiver's Hotshoe Passes ETTL information and Receivers have Hot Shoes. Some say they are built better than Pocket Wizards. Backwards & Forward Compatibility w/ Older & New Models. Upcoming Model will have ETTL and High Speed Sync.
Cons: Unknown Long Term Reliability.
(d) PocketWizard FlexTT5 -
Pros: Pocketwizard brand is the gold standard. Excellent Resell Value. Has all the high-tech features that no other company has yet
Cons: Extremely Expensive. Polarizing reviews.
At this point, I think I am going to bit the bullet and go with PocketWizard TT5 but some of the terrible reviews on BH are very concerning. If they are that bad, its probably no better than the other options. The Speedlites that I have in my bag is the older 430ex and 540ez non-ETTL. Not sure if there will range and interference issues with those
http://www.bhphotovideo.com …ave.html#pr-header-605720![]()
So what is your guys opinions on them????
