Thread started 05 Jul 2011 (Tuesday) 11:44
Think Tank Modular & Skin Components
KenVP
Jul 05, 2011 11:44 |  #1
More recently i have been looking at my on location set up and thinking there has to be a easier way. With that said I started searching around and noticed several photographers who i find to be inspirations to me to be using waist belts. I have since started looking into Think Tank products and was wondering if anyone on here is either using their modular components system or their skin components system? I am a very run and gun type shooter as my primary focus is journalism of emergency services so having the ability to bend, climb and move fast is a great advantage. I currently use two bodies one set for wide and one long and cargo pocket any extra gear. This system is better then the shoulder bag i started with but still stinks. I stay away from backpacks as I were shirts with my companies website across the back for ID. I look forward to any comments the good the bad lets hear it. Thanks
Mod system http://www.thinktankph​oto.com …ar-component-systems.aspx (external link)
Skin system http://www.thinktankph​oto.com …in-component-systems.aspx (external link)
bohdank
Jul 05, 2011 12:09 |  #2
I bought a harness and belt and combination of skin and modular pouches. I bought specific pouches for specific lenses. One thing I can say is you will need the harness and not just the belt ;-)a
It is much better than a shoulder bag for lens changing and more comfortable on a long day shooting.
hfgarris
Jul 05, 2011 21:23 |  #3
You might also like the TT "Change UP" belt bag as a starter, then add additional bags as necessary.
I agree, the harness is necessary, otherwise you may end up with the belt around your knees from the weight of the gear unless you cinch it up very tightly.
jim_escalante
Jul 06, 2011 07:52 |  #4
I use Think Tank's belt system. I am very pleased with it. I have purchased items from the skin component and from the modular component systems. I have one of the modular belts. Not the steroid version. I was surprised that I like the skin system as much as I do. Usually I go for more padding. In general use the skin component offers enough protection. The only thing that I prefer on the modular system is the fact that it does not have a flap for a cover. The open access makes it easier to put a lens in the modular system. I like the belt system very much. I opted to buy a few lens changer 50 from the modular component instead of getting different sizes. By having larger pouches, I can place any lens in any open pouch.
Jim
KenVP
Jul 06, 2011 17:04 |  #5
Thanks for the info.
SPK64
Jul 06, 2011 20:55 |  #6
I use a combination of skin and modular. Great setup. Let's me configure the belt for each event.
Canon 1dMKiii, 20d
Canon EF 70-200mm f/2.8 L IS
Canon EF 300mm f/2.8 L IS Canon 16-35mm f/2.8 L
Canon TC 1.4x Canon EF 16-35mm f/2.8, Tamron XR 28-75mm f/2.8, Canon 580ex
3 Einstiens, 2 64" PLMs, cybersyncs
bohdank
Jul 06, 2011 21:18 |  #7
I wish I was fatter, hence longer belt, hence more pouches :-)
I just realized, the pouches I have are mostly Modular. I also do not like the flaps on the Skins.
I run 2 cameras. The Camera Support Straps V2 work well with the Pixel Racing Harness. They come in pairs but I use them a little differently. 1 per camera. The cameras have Black Rapid Connect r3's.
1,783 views & 0 likes for this thread, 5 members have posted to it.
1391 guests, 174 members online
