Thread started 05 Jul 2011 (Tuesday) 16:15
2 strobes fired different times, long exposure
jobv2
Joined Jun 2011
Jul 05, 2011 16:15 |  #1
something i was wondering before i logged on and i am unable to do this at the moment.
if you have two flashes metered and setup to light a subject, will there be a difference in exposure if both flashes are fired at seperate times? say for example its a 2 second exposure, the first flash is fired immediately and the second flash is fired at 1second... how is this different than if both are fired at the same time?
1D Mark iin, 35mm f/2, 50mm f/1.4, 70-200mm f/4, 580ex ii, android, two left feet
gear| feedback
:cool:
Curtis ­ N
Master Flasher
Jul 05, 2011 16:34 |  #2
If no camera or subject movement during exposure, then no difference.
Or, to get a stop more power from your strobes, fire them, let them recycle and fire again before the shutter closes. But this only works in a dark environment where the ambient won't overpower the exposure.
jobv2
Joined Jun 2011
Jul 05, 2011 16:44 |  #3
yes i should have specified this would be in a dark environment.
i learned the hard way how ambient light can change at the drop of a dime.
i did not know about firing twice to get a stop more power...thanks
gear| feedback
:cool:
TheBurningCrown
Jul 05, 2011 16:47 |  #4
jobv2 wrote in post #12709244 (external link)
You can fire the flash as many times as you can get away with to build up the exposure. The problem is ambient creeping in and movement between shots (both for the camera and the subject).
-Dave
Gear List & Feedback
Wilt
Jul 06, 2011 13:43 |  #5
Each doubling of power is a geometric progression series...
1...2...4...8...16 gives you 0EV...1EV...2EV...3EV.​..4EV increase.
1,318 views & 0 likes for this thread, 4 members have posted to it.
2628 guests, 173 members online
