Thread started 06 Jul 2011 (Wednesday) 13:57
580 EX II as a fill in flash
aliengin
Joined Mar 2011
Jul 06, 2011 13:57 |  #1
I am using the flash 90% of the time as a fill in flash during races. Most of the shots are done against the sun. I noticed other photographers use the plastic diffusers.
Would it make any diffrence when shooting against the sun? Will it decrease the power of flash if I use the diffuser?
Ali Engin Photography (external link)
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
Jul 06, 2011 14:04 |  #2
aliengin wrote in post #12714192 (external link)
Not really and yes. You are likely too far away for an on camera diffuser to make any difference.
Image Editing OK
jobv2
Joined Jun 2011
Jul 06, 2011 14:10 |  #3
see post #3 by Wilt here https://photography-on-the.net …/showthread.php​?t=1060717
the links only show you the posts, but you should try to read the entire thread where those links are located.
but i hope Wilt comes in this thread and perhaps give you direct answer(s).
i know not much about lighting
1D Mark iin, 35mm f/2, 50mm f/1.4, 70-200mm f/4, 580ex ii, android, two left feet
gear| feedback
:cool:
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Jul 06, 2011 14:16 |  #4
digital paradise's answer is the short/sweet answer. Those little, plastic diffuser devices only work (at all) when there are surfaces to bounce off of...out it the open they just send light off into spaces that don't matter and reduce the amount of light reaching your subject.
aliengin
Joined Mar 2011
Jul 06, 2011 14:23 |  #5
jobv2 wrote in post #12714264 (external link)
Thanks a lot that was the answer I was looking for.
Curtis ­ N
Master Flasher
Jul 06, 2011 16:01 |  #6
My testing indicates that a plastic diffuser gives the 580EX flash a guide number of about 22 feet.
That means at f/10 it will have an effective range of about 2.2 feet for complete exposure, or about 3.1 feet for fill.
digital ­ paradise
Gallery: 157 photos
Jul 06, 2011 16:49 |  #7
Snydremark wrote in post #12714296 (external link)
For some reason I pictured the small softbox type of diffuser, not one that requires for something to bounce off when I responded the question. Gotta make sure not to make assumptions. Thanks for picking that up for me.
Image Editing OK
Tiberius
Jul 06, 2011 17:20 |  #8
The only way to soften light is to make the light source bigger. Stofen omnibounce type domes do not make the light source bigger. The simply direct light out to the sides more. Works well if you have nearby surfaces to bounce off, but out in the open it isn't likely.
If you are using an on-camera flash for fill outside, you aren't likely to get it any softer. About your best bet would be to have a guy holding a reflector so you could bounce the flash off that, but you could do that with the sun just as easily, eliminating the need for a flash.
My photography website!PHOCAL PHOTOGRAPHY (external link)
1,097 views & 0 likes for this thread, 6 members have posted to it.
2628 guests, 173 members online
