Thread started 08 Jul 2011 (Friday) 14:25
Why does opening a file in Photoshop from Aperture double the file size?
mikekelley
"Meow! Bark! Honk! Hiss! Grrr! Tweet!"
Jul 08, 2011 14:25 |  #1
So as I have been doing a lot of heavy editing, I've noticed for awhile now (maybe a year) that my computer has been sucking serious wind. Beachballs whenever I try to edit, hanging between switching programs (like going from Photoshop to iChat..) just generally being a pain in the ass. I decided to do some investigating and realized that the files I was working with were much, much larger than I anticipated. Before I open a file in photoshop, if I view the exif in aperture, the file size is around 12-15 mb (using a 5d classic). As soon as I open it in photoshop, the file size in aperture shows 34+ mb per photo before I even edit it! This is outrageous, and considering that I am usually editing photos with 15+ layers, file sizes quickly approach 1gb.
What the heck is going on? Is there a way to reduce file sizes when editing in aperture? I am using the right click - edit with - adobe photoshop command, aperture version 2. I have trouble believing that a late 2009 17" MBP with 4gb ram and 2.93ghz core duo processor would be failing so hard editing files from an almost 7 year old camera.
Los Angeles-Based Architectural, Interior, And Luxury Real Estate Photography (external link)
How To Photograph Real Estate and Architecture (external link)
My Fine Art Galleries (external link)
My articles at Fstoppers.com (external link)
Mark-B
Jul 08, 2011 15:02 |  #2
The RAW file is being converted to a TIFF file during export. TIFF files are much larger. You are getting 34+ mb without layers. If you were doing heavy editing and saving the file with many layers, the file size could grow to 100 mb.
Options to reduce file size are to use compression when saving, flatten image before saving, or save as a JPG once your edits are complete and delete the TIFF.
Alternately, if your main problem is with processing power and not disk space, you could just export the pictures you want to edit to your desktop, close Aperture, then manually open Photoshop. This would greatly reduce your CPU/memory usage.
Mark-B
msbphoto.comexternal link
Bobster
Jul 08, 2011 15:32 |  #3
are they 16bit TIFFs?
Robert Whetton (external link) Dorset Portrait & Events Photographer | Photoshop Guru
Gear | Gram (external link) | Ultimate Lens MA FoCal 2 (external link)| Ultimate RAW Editor C1 (external link)
mikekelley
Jul 08, 2011 17:41 |  #4
The only options are tiff and psd. it's about the same size with both. is there no way to edit the cr2 file to keep it reasonable?
TheLostVertex
Jul 08, 2011 18:44 |  #5
To add a little bit here...
RAW files on a 5d classic are 12bit, while your tiffs are likely 16bit, which is a large difference. Adding to this RAW files are compressed using lossless compression in most cases(unsure about the 5dC, but I would imagine so) While some types of tiffs are compressed, the ones aperture is sending out are not. There is the bulk of the file size differences right there.
Now for the problem solving part, which is a bit tricky. And the question comes down to size, performance, and quality. Knowing that you do alot of stacking and post work on your photos(which are great btw :)) I will assume that you dont want to change from 16bit to 8bit. Doing so would reduce file size and increase performance.
If you want to purely save space then you can save the image as a tiff with LZW or ZIP compression, both are lossless, support layers, and will reduce file size quite alot.
If you want performance than just saving as a psd will likely be the best option, but will also take up more space. Turning off maximize psd compatibility when saving will reduce the file size, but aperture wont be able to view the psd file then.
You can edit the cr2 file in photoshop technically, by loading it as a smart object. The problem here is two fold. One you will lose all settings from aperture since the raw file will be processed by abobe camera raw(though you can change the raw processing any time through your edit, which is a plus). The second issue is this will be the largest file size form all the solutions here because photoshop saves the raw file inside the psd, saves the settings to process it via adobe camera raw, and saves an uncompressed render over what the current layer state is(if you have "Maximize psd compatibility" on).
So what do you want most? To save space, or increase performance? Maybe there are some other things to help with either of those if we have a target.
Steven R.
500px (external link)
tzalman
Fatal attraction.
Jul 09, 2011 03:51 |  #6
TheLostVertex wrote in post #12727279 (external link)
The tifs are 48 bit (3 channels X 16) which is an even larger difference.
However, that will do nothing to speed up PS because the first thing PS does is to decompress the image data and restore it to its full size (12.7 MP X 6 bytes = 72.7 MB).
BTW, the OP mentioned having tif/psd files of 36 MB, so apparently he is working in 8 (24) bit.
Elie / אלי
Mark-B
Jul 09, 2011 06:23 |  #7
I have 527 TIFF files in my Aperture library.
Mark-B
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Jul 09, 2011 06:35 |  #8
mikekelley wrote in post #12726037 (external link)
The 5D came out in 2005, shortly before the Core 2 Duo came out in 2006.
At the time the 5D came out it made for a heavy work load on desk top computers, it is no wonder your laptop from the same era has problems.
You can either put up with the slow performance, shoot and edit JPEG, or buy a current generation computer.
Have you Calibrated your Monkey lately?
Now more than ever we need to be a community, working together and for each other, as photographers, as lovers of photography and as members of POTN.
René ­ Damkot
Jul 09, 2011 08:14 |  #9
Beachballs when switching programs generally indicate disk swapping. Get more Ram.
http://macperformanceg​uide.com/Mac-Ways.html (external link)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jul 09, 2011 08:46 as a reply to  @ René Damkot's post |  #10
My ancient stock XP COMPAQ computer has very little trouble processing 200MB files with a lot of layers, but I've added a 2nd hard drive & don't make it keep track of other open programs at the same time.
Have you checked to see what legacy software crud is running in the background?
frenchconnector
Jul 09, 2011 10:43 |  #11
You need more RAM, 4GB is not enough while working with 1GB PS files, while also using Aperture and maybe having Safari or Mail open all at the same time. Closing all apps beside PS and A3 should help. Also make sure, that if you have a dual video card, you are using the faster one in your System Prefs>Energy Saver as both PS and Aperture (at least Aperture 3, not sure about 2) rely on GPU for faster processing.
And I don't think starting with 15MB file or 30MB file will make that much difference, it's the layers that add up to 1GB and higher. And the reason why they are bigger has been mentioned, they have either twice (24bpp) or three times (48bpp) the bit depth of a 12 bpp raw file. There is no way to avoid this once you convert the image from raw into a bitmapped file for doing your layer work in PS.
igorpilot.com (external link)flickr (external link)tweet tweet (external link)
mikekelley
Jul 09, 2011 12:57 |  #12
Wow, great post. Thanks so much. Ideally I'd like to increase performance - I have plenty of space as it stands, so I don't mind a bigger filesize if it helps performance.
Moppie wrote in post #12729028 (external link)
For some reason I don't think these are the only solutions.
René Damkot wrote in post #12729186 (external link)
I've been pondering more ram for awhile now - this might push me over the edge. :)
PhotosGuy wrote in post #12729254 (external link)
That gives me some hope. I've used activity monitor to see what's going on in the background, and there doesn't seem to be too many shenanigans.
frenchconnector wrote in post #12729748 (external link)
Good advice again, thanks! I will look into upgrading my ram to 8gb or so.
Thanks to everyone who offered helpful advice :) I'm going to see if I can look into a RAM upgrade and try to cut down on background program 'loitering' so to say. Hopefully this helps.
Heath
Joined Sep 2009
Jul 09, 2011 13:11 |  #13
I have a mid 2008 iMac that is having similar issues trying to edit files between lightroom and photoshop. And I am just starting out, not nearly doing the work that Mike is doing. Playing around with 3 image merges and luminosity masks.
After looking at the Activity Monitor, it is definitely more of a RAM issue than a processor issue.
I am trying to figure out if I spend the money on more RAM for a 2008 iMac, or whether I buy a new iMac.
Edit: Just looked, and my version of the iMac will not take more than 4GB of RAM, which is what I have. Any suggestions or am I out of luck and need a new machine.
Heath
"Some photographers push the envelope. Some sit behind a keyboard and criticize their accomplishments." (seen in the comments of a photo article)
Blog (external link)-Twitter (external link)-Zenfolio (external link)-500px (external link)-Pinterest (external link)-Gear List
René ­ Damkot
Jul 09, 2011 14:48 |  #14
2008 supposedly supports up to 6Gb of Ram: http://www.everymac.co​m …ly-2008-penryn-specs.html (external link)
Don't know if it will help much though.
New iMac will be *much* faster. (as will any 2011 MacBookPro)
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Jul 09, 2011 17:35 |  #15
mikekelley wrote in post #12730228 (external link)
Really? Based on experience I think you'll find they are.
Ram is cheap, and will improve the performance: http://www.newegg.com …00-_-20-233-179-_-Product (external link)
But, your moving very large files from disc, to memory to CPU to memory back to disc.
In order to do that quickly you need a fast disc, fast BUS, a fast CPU and lots of fast memory.
Your laptop, being a laptop, and using technology that is now 3 generations out of date, has a comparatively slow disc, slow memory, slow BUS and slow CPU.
5,619 views & 0 likes for this thread, 10 members have posted to it.
1676 guests, 137 members online
