None scientific test of the two straight out of the camera with no processing. Other than the sun may have came out a little on one of the photos.
stlouis_26 Senior Member 304 posts Likes: 4 Joined Sep 2009 More info | Jul 08, 2011 14:38 | #1 |
Sam6644 Senior Member 691 posts Likes: 3 Joined Jan 2010 Location: Cincinnati, Ohio More info | Jul 08, 2011 14:40 | #2 Conclusion? my site (very outdated at this point)
Jul 08, 2011 14:45 | #3 Sam6644 wrote in post #12726102 Conclusion? I am not sure. When I shoot jpeg I always use the highest quality L but the lowest S may work for general pics that are not going to be enlarged. My next test will be to enlarge a couple up to 8x10 after doing some processing. I guess I expected to see a big difference in the quality.
shedberg Goldmember 1,122 posts Likes: 1 Joined Mar 2010 Location: Terrace, B.C. Canada More info | Jul 08, 2011 15:07 | #4 Top one looks sharper. My Flickr Page
Jul 08, 2011 15:30 | #5 shedberg wrote in post #12726282 Top one looks sharper. I think it is because the sun came out for a second. Top one is actually the lowest S and the bottom one is the highest L.
krb Cream of the Crop 8,818 posts Likes: 8 Joined Jun 2008 Location: Where southern efficiency and northern charm come together More info | Jul 08, 2011 15:34 | #6 Because the best way to compare two different resolutions is to shoot under changing lighting, resize them both to a web sized image and then save them at a low enough jpeg quality to comply with this site's limits on file size... -- Ken
Jul 08, 2011 15:34 | #7 Really hard to tell the L, M, or S apart. I am sure the enlargements will be more noticable. I guess I just expected a really big difference because honestly I had never ventured off of the High L setting when I did jpeg. For prints I want to hang on the wall I shoot raw.
tkerr Goldmember 3,042 posts Likes: 2 Joined Mar 2010 Location: Hubert, North Carolina, USA. More info | Jul 08, 2011 16:43 | #8 stlouis_26 wrote in post #12726119 I am not sure. When I shoot jpeg I always use the highest quality L but the lowest S may work for general pics that are not going to be enlarged. My next test will be to enlarge a couple up to 8x10 after doing some processing. What are you processing Jpegs with, and what kind of processing are you doing to them? stlouis_26 wrote in post #12726119 I guess I expected to see a big difference in the quality. With jpegs you won't see a difference because they are processed in the camera with all the camera settings and then reduced in size. The only difference you should see is the dimensions and file size. Tim Kerr
Jul 08, 2011 16:55 | #9 For jpegs I use Elements 6 (thinking about going to 9) and generally adjust whatever needs to be done with the picture. Ok I was not aware there would be no difference. I guess the difference would show up in the enlargements then? I just shoot Raw and process it in DPP or CS4 depending on what computer I am using at the time.
Jul 08, 2011 16:58 | #10 Missed part of your question, I mainly adjust color and sharpen the jpegs.
tonylong ...winded More info | Jul 09, 2011 03:27 | #11 Since you are compressing your images to a Web-size image then techinically there is no difference. There is, of course, a difference in how you might process an image, especially if you compare Raw to a jpeg for processing, but taking a Large jpeg and shrinking that down and comparing it to a Small jpeg should show little if any difference, depending on whether the camera uses a different process for the different formats. Tony
NinetyEight "Banned for life" More info | Jul 09, 2011 03:27 | #12 krb wrote in post #12726439 Because the best way to compare two different resolutions is to shoot under changing lighting, resize them both to a web sized image and then save them at a low enough jpeg quality to comply with this site's limits on file size... {insert random 'face palm' image here} My thoughts exactly! Kev
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Jul 09, 2011 09:06 | #13 stlouis_26 wrote in post #12726095 None scientific test of the two straight out of the camera with no processing. Other than the sun may have came out a little on one of the photos. Not that different on this size. "I think the idea of art kills creativity" - Douglas Adams
| Latest registered member is Monkeytoes 1358 guests, 188 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
