Thank you all for the input.
phreeky wrote in post #12741651
OK then yeah it sounds like the lens has an issue. It's probably quite a minor problem but also a fair bit of work to get to the part to fix it. If you're not confident pulling a lens apart to fix it then you'll either have to live with it or send it to a repair centre to get fixed.
Any guidelines to perform this task (repair)?
I'm buying other lens to replace this in the next moth - not because of this, but more for an upgrade. If I have some instructions I may attempt to repair it, otherwise I may will leave it as it is.
Snydremark wrote in post #12741750
Are the contacts on the lens dirty/corroded?
It looks normal. I've already cleaned it.
