Thread started 11 Jul 2011 (Monday) 23:19
focusing issue after adjustment from Sigma
Dr.TC
Joined May 2011
Jul 11, 2011 23:19 |  #1
so i had my Sigma 85 adjusted and just got it back today.
one question tho, am i suppose to get sharp images at 1.4?
because it still seems soft to me!
and at what aperture would the image be sharpest?
any ideas?
s2kennyc
Jul 11, 2011 23:22 |  #2
From my sampling of the lens, it should be pretty darn sharp wide open at F1.4. It only gets better from there. Perhaps post a sample image with EXIF data intact and we can tell you whether it looks ok or not?
-Ken
Dr.TC
Joined May 2011
Jul 12, 2011 19:49 as a reply to  @ s2kennyc's post |  #3
all images are focused at the word "phosforic" beside the dot
@ F1.4, 1/100, ISO 160
@ F2.2, 1/100, ISO 400
@ F2.8, 1/100, ISO 640
bohdank
Jul 12, 2011 20:07 |  #4
Based on those I don''t see a problem. Why do you feel it is soft ?
Dr.TC
Joined May 2011
Jul 12, 2011 20:26 |  #5
i feel that it is soft when i am taking portraits. when i focus on the eyes, it is not SHARP SHARP.
this is why i dont know how sharp would be normal...
bohdank
Jul 12, 2011 20:32 |  #6
Maybe it is your technique. If you are new to very fast lenses, they can expose problems in technique like locking focus and then swaying/leaning into the shot or other mannerisms before tripping the shutter.
At 1.4 you have a minute amount of DOF on a head shot. It takes very little to move the point of focus. If you can, try taking that portrait with the camera on a tripod and make sure you tell the subject not to move.
What camera are you using ?
s2kennyc
Jul 12, 2011 23:24 |  #7
Those sample shots look fine to me.
As for portraits, hitting focus at F1.4 can be tricky sometimes. As Bohdan had mentioned already, It could be your technique or it could be your subject moving slightly. It just takes practice.
Also, 1/100 shutter speed for this lens might also be a bit too slow if you are shaky at all. Try bumping up your ISO to get a faster shutter speed if you can.
-Ken
Sdiver2489
Joined Sep 2009
Jul 12, 2011 23:50 |  #8
focusing on eyes is hard, you'll often get the eyelash or the eyebrow which at 85mm F1.4 is more than enough to render the iris out of focus. IF you really want perfect focus on the eye each time, you'll likely need a studio like environment and manual focus in live view. Eyes are often too small to reliably grab.
But those bottle shots look perfect...very impressive.
Please visit my Flickr (external link) and leave a comment!
Gear:
Canon 5D III, Canon 24-70L F4 IS, Canon 70-300L F4-F5.6 IS, Canon 100mm F2.8L IS Macro, Canon 35mm F2.0 IS, Canon 430EX II-RT, Canon 600EX II-RT
KVN ­ Photo
Joined Jun 2010
Jul 13, 2011 06:03 |  #9
Is it me or I couldn't see the difference in sharpness for the bottle test. All look pretty sharp to me.
X-Pro1 + 18-55 f/2.8-4 OIS + 55-200 f/3.8-4.5 OIS
TS-E 24 f/3.5L II + XF 35 f/1.4 + XF 56 f/1.2
Sony RX100 II + G12
Travel the world!
yogestee
Jul 13, 2011 06:28 |  #10
Dr.TC wrote in post #12748446 (external link)
Look,, most lenses, even topshelf models aren't at their best wide open. Close them down a stop or two and things begin to heat up..
My 135L which is quite sharp at f/2. Stop it down to f/2.8 or smaller and it's razor sharp.
Jurgen
Dr.TC
Joined May 2011
Jul 13, 2011 07:33 |  #11
im using a 5D mark2.
if it is my technique, how can i improve on camera shake?
bohdank
Jul 13, 2011 07:44 |  #12
It's probably not camera shake but either, or both you and the subject (portrait), moving between getting focus and tripping the shutter. You have to be aware of your subject. If they move their head slightly, refocus. When you focus, just be conscious of your body. Don't move. Get comfortable with your shooting position and don't move. It might feel weird at first but it becomes second nature quite quickly. There really isn't a specific technique that I can recommend. You just have to do it.
I had the same problem when I got the 85/1.8. I got used to shooting with f2.8 lenses that I didn't realize I was leaning my upper body slightly forward just before tripping the shutter or my subject had moved their head or body.
It's a little more dsifficult for me since, often, I have my subject moving between shots and an untrained subject needs some coaching so they freeze their pose between movements. I usually communicate by saying something like, GO, between movements so the subject knows I have the shot and they can now change. It's important to develop a rhythm. It makes for faster shooting but, ultimately, more interesting images. I also pretty much always shoot in AI Servo And time the shutter release to when I think I'm focusing where I want to. Practice makes perfect.
rick_reno
Jul 13, 2011 08:39 |  #13
those bottle shots are excellent. i don't think it could get much better.
pulsar123
Gallery: 82 photos
Jul 13, 2011 08:43 |  #14
Which focusing are you using - "fast" (phase detection), or Live View "slow" (contrast detection)? I believe most of the times fast lenses appear to be soft is not because of poor/uncalibrated optics, but because the "fast" AF is not accurate enough (this can be adjusted using focus MA feature if your camera has it, or calibrated by SIgma).
Here is the test: take the same shot of the bottle twice: once with fast AF, second time - with Live View AF (make sure you zoom in in Live view to the maximum). For both shots, use tripod, enable lockup of the mirror (in the camera menu), and use either wireless trigger or 10 seconds timer. Make sure there is plenty of light. Then pixel-peel at both shots - if the Live View shots look much sharper than the fast AF shot, you might have an issue with the AF calibration (or may be you didn't focus properly - try to do similar tests with other targets, to confirm).
6D (normal), 6D (full spectrum), Tamron 24-70 f2.8 VC, 135L, 70-200 f4L, 50mm f1.8 STM, Samyang 8mm fisheye, home studio, Fast Stacker
yogestee
Jul 13, 2011 10:09 |  #15
pulsar123 wrote in post #12750818 (external link)
I disagree!
First one has to establish if the lens/camera combination is misfocusing or if the lens is optically unsharp at full aperture.. There is a difference.
If you don't do this,you'll be only chasing your tail.
Jurgen
1,411 views & 0 likes for this thread, 8 members have posted to it.
2733 guests, 144 members online
