Thread started 13 Jul 2011 (Wednesday) 18:24
Contrast and phase detect in live view
r.morales
Jul 13, 2011 18:24 |  #1
Can someone explain ? Was reading about for MA -ing on another site .
Not real clear in books or on web [at least where I looked .]
HughR
Jul 13, 2011 19:50 |  #2
r.morales wrote in post #12753799 (external link)
Your post is totally incomprehensible. Say something a bit more coherent, and maybe you'll get an answer.
Hugh
Canon 60D, Original Digital Rebel (2003)
EFS 15-85mm IS USM, EF 70-300mm IS USM, Tokina 11-16mm
Speedlite 430EX, Speedlite 430EX II,
Qbox 16 pro, Lastolite EZbox 24x24, Lumiquest Softbox III
krb
Jul 13, 2011 19:55 |  #3
Phase detection is the "normal" focus detection method used by the camera.
Contrast detection is the focus detection method used in LiveView.
Contrast detection is more accurate and it is not limited by lens aperture but it operates much more slowly.
-- Ken
Gear list
oldvultureface
Gallery: 85 photos
Jul 13, 2011 20:25 |  #4
HughR wrote in post #12754149 (external link)
I think he's referring to comparing pictures of a test target using both contrast and phase detect AF to determine a micro-adjust setting. Take a picture using live view contrast AF. Take another using phase detect AF. Compare the two for focus and micro-adjust accordingly.
Is this correct, OP?
r.morales
Jul 14, 2011 00:22 |  #5
Yes , I am still getting different results when I MA .
I tried looking in manual , 7D Digital field guide and a short course in EOS 7D .
I downloaded the canon manual [Bigger print = easier to read]
I tried the flat poster on wall [old bug ID chart] popped the mirror out of a cheap makeup case and glued to it . 3 shots - 17-55 fine , 3 shots 70-200 all over place .
I did the ruler at an angle thing [architect scale] at about 15 feet - 17-55 fine 70-200 off , tried + and -5 , 10 and 15
I did not like any seemed "0' was better .
Looking for something else to try and found the contrast and phase detect .
So contrast is the live view and phase detect is the normal ?
I was just taking the shots and then put everything away and look at on computer .
Thanks .
AbPho
Jul 16, 2011 21:43 as a reply to  @ r.morales's post |  #6
Article on lensrentals.com (external link) about phase detection versus contrast detection.
I'm in Canada. Isn't that weird!
r.morales
Jul 17, 2011 11:25 |  #7
Thanks . makes more sense now . I bookmarked and copied and pasted on to a document .
Now I have to go back and read up on Histograms .
2,206 views & 0 likes for this thread, 5 members have posted to it.
1588 guests, 138 members online
