Thread started 16 Jul 2011 (Saturday) 21:50
Will I REALLY be able to see the diffrence between the 18-55 IS and the Tamron 17-50
domat
Joined Jun 2010
Jul 16, 2011 21:50 |  #1
Maybe I should have asked this before my purchase. Just won an auction for the 17-50 non vc. Now I wonder if it will really be a big change. I am fairly sure that they both will last so build quality is not a factor to me. Faster focusing would be nice but the nifty 50 gets bad rap for having slow focus and yet I get decent action shots like these
https://photography-on-the.net …/showthread.php​?t=1068201.
I get sharp images with my kit lens but not as sharp as I see with other lenses but I always wonder how much is user and PP vs the actual lens. occasionally seeing some putrid pictures posted by some like the ones I saw today using a 5dII and 70-200 2.8 is makes me think it is the former.
Well I can always sell it.
Thanks for listening to me rambling on.
GregoryF
Jul 16, 2011 22:09 |  #2
It will be sharper, but louder. It will definetely be much better at f2.8 than the kit lens!
6D, 5D, 7Dii, Eos R and too many lenses, flashes and aux. gear to list!:cool:
A simple hobby gone horribily wrong
patman530
Jul 16, 2011 22:25 |  #3
You will be able to see the difference.
EOS 5D Mark II | EOS 40D | EF 17-40 f/4L | EF 24-70 f/2.8L | EF 85 f/1.2L II | EF 70-200 f/2.8L IS | EF 50 f/1.8 II
Carlwashere
Joined May 2011
Jul 16, 2011 23:26 |  #4
Hands down, big difference. No doubt. The 18-55 is a capable lens, but the upgrades in your new lens will be quite noticeable. f2.8 locked aperture, sharpness, and it focuses a bit faster.
-Canon T2i- -Tammy 17-50 non-VC- -50 f1.4- -100 f2.8 macro- -85 f1.8-
-Pentax SP1000- -SMC Takumar 55 f2- -Takumar 28 f3.5- -Vivitar 135 f2.8-
tab
Jul 17, 2011 06:16 |  #5
Don't worry. I received my Tamron yesterday and after playing with it and comparing it with the Canon 18-55mm IS you will be able to tell the differance in IQ between the 2 of them. I was like your self a little apprehensive about the upgrade once I had ordered mine, but after using it, is in my opinion well worth the upgrade. Plus you will have a lens that is consistent across its range at 2,8.
I am really looking forward to using this lens
Canon 7d, Canon 450d, 18-55mm kit lens, 55-250mm lens, Tamron 17-50mm non VC, Tamron 70-300mm VC
lsuber
Jul 17, 2011 07:49 |  #6
I made that same move several years ago, and you'll definitely be able to tell a difference. The Tamron lens has a very very good reputation, and for good reason. The only negatives (if you consider them as such) are that it's noisy when focusing, and the zoom ring turns the opposite way from the Canons. You may not care about either, though. But it's optically a very good lens. On the long end, it's a long way from the 18-55's f/5.6 to the 17-50's f/2.8. You'll be able to do some things with it that the kit lens cannot do.
Canon 5D Mark II | 28-70mm f/2.8L USM | Σ 70-200mm f/2.8 APO EX DG HSM OS | 85mm f/1.2L USM | Σ 50mm f/1.4 EX DG HSM | 50mm f/2.5 Compact Macro | LR5 | PS CS5
pulsar123
Gallery: 82 photos
Jul 17, 2011 07:58 |  #7
An f2.8 17-50/55mm lens (like Tamron) can realistically replace both the kit lens, and the nifty-fifty (at 50mm f/2.8 it's a pretty decent portrait lens; nifty-fifty is not very useable below f/2.2 anyway) - so you'll have to change your lenses less frequently - which means fewer lost opportunities for a shot.
6D (normal), 6D (full spectrum), Tamron 24-70 f2.8 VC, 135L, 70-200 f4L, 50mm f1.8 STM, Samyang 8mm fisheye, home studio, Fast Stacker
twoshadows
Liquid Nitrogen
Gallery: 52 photos
Best ofs: 19
Jul 17, 2011 09:47 |  #8
Imo, you won't see much of a difference and the Tamron is LOUD. I'd save up for a sigma 17-50 OS.
xgender.net (external link) Miss Julia Grey (she/her/Miss)
The Chronochromagraph "how to" thread
District_History_Fan
Jul 17, 2011 10:11 as a reply to  @ twoshadows's post |  #9
The only thing you will gain is constant f/2.8 and a modest build quality improvement. You'll loose IS and possibly AF stability. Your wallet will certainly be lighter. IMHO you'd be better to save up for a decent lens (ie, not Tamron) or keep the Canon kit lens.
www.ericmcferrin.smugm​ug.com (external link)
watt100
Jul 17, 2011 11:10 |  #10
domat wrote in post #12770991 (external link)
For me it was a significant step up having a sharp f2.8
I use to try these shots with a tripod now I can just handhold with the Tamron and the pics look better
e.g.
XSi (450D) with Tamron 17-50 2.8
f2.8
at ISO 1600
handheld
IMAGE: http://farm6.static.flickr.com/5228/5764071955_bdbb81ef2a_b.jpg
BrickR
Joined Mar 2011
Jul 17, 2011 12:34 |  #11
The Tamron 28-75 f2.8 was my first lens purchase and the difference in IQ between it and the kit lens was immediately apparent. I quite using my kit lens for everything but video (for the IS). For photos the kit lens doesn't get used unless mandatory for wider range.
My junk
The grass isn't greener on the other side, it's green where you water it.
muusers
Joined Sep 2009
Jul 17, 2011 12:48 |  #12
For some reason i knew i would find a christmas choir in this topic. :P Watt100, you're sure fond of that image :P
But to answer the OP; Yes.
50D + 17-55 | s100 | flickr (external link)
lsuber
Jul 17, 2011 13:17 |  #13
I agree with twoshadows: relative to other lenses, it is a loud sucker. That and the reverse zoom ring direction eventually became annoying enough that I moved on. Mine made enough focusing noise that at times it caused people in a quiet room to turn and look when I was trying to get a candid shot. Canon's 17-55mm f/2.8 was great on a crop, and then I got a 28-70L for my current FF body. The image quality difference is there, but it's not enormous. The quiet operation and better build are welcome!
CountryBoy
"Tired of Goldmember label"
Jul 17, 2011 13:45 |  #14
Yes you will see a difference in IQ .
Hi
artyH
Jul 17, 2011 13:53 |  #15
Whenever I raise this question myself, I look at my travel photos of Rome and Oslo. I then go out an buy a lens that will complement, but not replace the 18-55IS. The last one I got was the Tokina 12-24.
If you are unhappy with the photos your kit lens gives you, get an upgrade.
I use zoom lenses for travel, and rely on primes for most other things. For me, it is not worth getting another general purpose "normal" zoom right now. If you want f2.8 for indoor photography, then it makes sense to get the Tamron, if it will do well at f2.8. I tend to use fast primes for this environment. You may prefer a relatively "fast' zoom for the same purpose.
I like the results I get from the 18-55IS, and I thought that your photos of your dog were pretty good.
3,062 views & 0 likes for this thread, 17 members have posted to it.
1201 guests, 168 members online
