So get a USB CF reader or use the USB cable that came with the camera. That's not a reason to swap bodies, IMO, unless you have too much money to burn.
echo-3 wrote in post #12780661
I go to a lot of conventions for one, but stuff like wedding's where they dont like flash photography.
I want to like the t3 @ the $500 point ..Im just not sure if Im making a good choice. But I guess any newer model will be better then my current Rebel XT.
My # 1 choice to get something new is ,Im trying to get away from Compact Flash.
The best thing for low light is to get a larger aperture. If you get the T3, you'll still be stuck with your two pretty low end f5.6 lenses and you'll be running out of light in anything but daytime. The T3 can do decent 3200, but it still doesn't look as good as the XT at ISO 800, which you can do with an f2.8 lens. Or in the same light with an f1.4 lens you could be at ISO 200. I'll take 8 megapixels of the XT at ISO 200-800 over 12MP of the T3 at ISO 1600-6400. I would put your $600 towards a faster lens or two if you want to see some real improvement in image quality. If you just want bells and whistles but the same pictures, then get the newer body.
