Thread started 21 Jul 2011 (Thursday) 22:23
"External Flash attached": NOT
mikecox
Joined May 2011
Jul 21, 2011 22:23 |  #1
I was on a shoot today and needed some filler light, so I hit the flash button, to pop up the flash, and nothing happened.
When I checked the menu/Flash control/Built-in Flash Func setting the following message appeared: "This menu cannot be displayed. External flash is attached". But it isn't! :confused:
I put to external flash on the camera and removed it again; thinking it might, somehow reset but it didn't change anything.:cry:
Is there a menu setting that, if set, would cause the camera to think an external flash was attached, or is my camera broken?
Michael :cool:
Canon 60D and 70D, Speedlite 430 EX II, PsCC, LrCC, and PrE 16
krb
Jul 21, 2011 22:25 |  #2
there is a very small microswitch under one of the metal ears on teh hot shoe, that's how it detects that a flash is attached. sometimes a little bit of grit can get in there and stick it down. Try using a toothpick to jiggle that switch and see if that fixes it.
-- Ken
Gear list
mikecox
Joined May 2011
Jul 21, 2011 23:00 |  #3
krb wrote in post #12802121 (external link)
Bingo :D That was it. Thanks!
btw how did you get the Flickr link into your sig?
Michael :cool:
krb
Jul 21, 2011 23:07 |  #4
Do you mean how did I make it a link or how did I do the colors or...?
-- Ken
Gear list
AbPho
Jul 21, 2011 23:39 as a reply to  @ krb's post |  #5
Like this:
<a href="http://www.flick​r.com/photos/blahblahb​lah/" target="_blank"><b><font color="blue">Flick</font><font color="red">r</font></b></a>
I'm in Canada. Isn't that weird!
mikecox
Joined May 2011
Jul 21, 2011 23:39 |  #6
krb wrote in post #12802329 (external link)
This link; I think I'll be able to figure out the colors.
Michael :cool:
AbPho
Jul 21, 2011 23:48 |  #7
I am wrong. It's BB CODE not HTML.
krb
Jul 21, 2011 23:59 |  #8
mikecox wrote in post #12802469 (external link)
url=www.flickr.com/ (external link)
flickr
/url
The above is the lines to use but you have to enclose the first and last lines in square brackets. If you click the quote button you can see a sample of quote tags and the URL tag follows the same basic format.
-- Ken
Gear list
mikecox
Joined May 2011
Jul 22, 2011 00:05 |  #9
AbPho wrote in post #12802468 (external link)
Like this:
I added this; exactly as shown...
<a href="http://www.flick​r.com/photos/mikecox_/​" target="_blank"><b><font color="blue">Flick</font><font color="red">r</font></b></a>
But it isn't showing up.
I even removed a line before adding it by putting the attribution for my quote on the same line.
Michael :cool:
krb
Jul 22, 2011 00:09 |  #10
mikecox wrote in post #12802548 (external link)
like he said in his follow-up, that doesn't work within the forum. that's what is actually sent to everybody's web browser when they see it but the form doesn't let you post the actual codes like that.
-- Ken
Gear list
mikecox
Joined May 2011
Jul 23, 2011 17:09 |  #11
krb wrote in post #12802527 (external link)
flickr
/url
Sorry:oops:
Do you mean to use the quote tab; like I'm seeing here in the quoted section?
If I follow exactly what you said exactly it sounds like I would put the entire section inside a pair of square brackets; which doesn't sound right.
Michael :cool:
krb
Jul 23, 2011 17:17 |  #12
Look closer at the quote section. There are square brackets around the "quote=..." part and then another set of square brackets around the [/QUOTE] section. Same thing for the "url=..." and the "/url" part.
-- Ken
Gear list
mikewinburn
Jul 23, 2011 17:22 |  #13
michael,
a) go to your flickr page, sign in and go to the "My account tab""
b) highlight your "photostream" address and copy it
c) come back to POTN,and hit the "quicklinks" tab, andselect edit signature
Then:
1) write the word flickr
2) add the color to the letters
3) selected the 'hyperlink" tool...(if you hover over it with your cursor it says,ïnsert link",
4) paste the address from the flickr page there
8) save it.
Voila
I think that's what you mean?
it edited the steps above to confirm, you have to do it in that order since once the ïnsert link" boxis open, you can't navigate away to another page. Also, if you get the yellow bar telling you to allow script, youshould allow it, or it won't work.
Gear: The Official Gear List / Market Feedback / Sig thread #2468
WinburnCreations (external link)
mikecox
Joined May 2011
Jul 23, 2011 17:36 |  #14
mikewinburn wrote in post #12810620 (external link)
Awesome; it worked! Thanks
Michael :cool:
tonylong
...winded
Gallery: 60 photos
Jul 23, 2011 17:47 |  #15
Ah, never mind my goofed-up attempt!
Tony
3,746 views & 0 likes for this thread, 5 members have posted to it.
1320 guests, 160 members online
