Thread started 22 Jul 2011 (Friday) 14:01
Phottix PPL-200 Power Pack
williejr
Jul 22, 2011 14:01 |  #1
http://www.phottix.com …es-and-studio-lights.html (external link)
Anyone out there try this battery pack that can make a comparrison to the 2x2 Turbo?
Body: Canon 5D Mark III, 1D Mark IV,
Lens: 85mmL F1.2, 70-200 L F2.8 II, 24mm 1.4 II L II, 35mm F1.4 L, Flashes: 3x 580EX II,
tongki
Aug 01, 2012 14:44 |  #2
williejr wrote in post #12805385 (external link)
anyone know this pack compatible to Quantum cables ?
how about the battery voltage inside ?
found out Godox with 9.6V are not ideal
EOS 70D x 2 units + EOS 7D mark II x3 units
Newton FR3, Newton modified bracket, EF 17-40mm x4,EF 24-70mm f/2.8 x2, EF 70-200mm f/2.8 x2
Quantum Trio x2, T5D-R x1 + FW7Q x1, CoPilot x2, Godox AD-180 x5
Propac PB960 head x12, PB960 battery x10
sorry, no stupid speedlite from Canon !
msowsun
"approx 8mm"
Gallery: 18 photos
Aug 01, 2012 15:14 |  #3
The Phottix PPL-200 plugs into the 300 volt input on Canon and Nikon flashes. I would assume that the output voltage is stepped up to 300 volts just like a Canon CP-E4.
Do the Quantum and Godox power packs also put out 300 volts?
Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.8 STM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
tongki
Aug 02, 2012 04:29 |  #4
msowsun wrote in post #14801061 (external link)
Godox does mentioned that their product are compatible to Quantum, also the cable,
I can not find any info that Phottix are Quantum compatible
they have to, high voltage input to external port flash should be similar power
tongki
Aug 02, 2012 04:32 as a reply to  @ tongki's post |  #5
hey, found a way,
what is the adaptor power of Phottix ?
because Godox with 9.6V battery inside should be powered by 9.6VDC adaptor
2,772 views & 0 likes for this thread
Latest registered member is Big_coelho
910 guests, 271 members online
