Yes, another UV filter thread. But for this one I'm not asking questions, simply commenting that paying more for a quality filter really, really does matter.
I got a "free" Tiffen UV filter with my T3i kit + 55-250mm lens combo special. I also ordered a Hoya filter kit (with extras like a Lenspen) that included the HMC UV(C) filter. I had ordered the Hoya HMC UV(C) on purpose because I read the reviews at Lenstip.com, as linked from somewhere here at POTN:
http://lenstip.com …icle-UV_filters_test.html![]()
I assumed that I probably wouldn't notice the differences in most conditions, but thought it worth while "just in case".
This morning I took a few shots with the Hoya and a couple with the Tiffen attached to my 55-250mm lens to see if I could easily see the difference. The sun is outside the field of view, above the top of the tree, maybe 1/4 or so of the height of the image away. The results speak for themselves:
Hoya HMC UV(C)
Tiffen UV (no specific coating specified, so probably none)
I can't believe how freaking obvious that is.
I was going to take a shot with no filter, but some clouds moved over the sun and I couldn't re-create the conditions in time.
So this thread is for all those folks thinking cheap filters are almost as good as the expensive ones because "it's just thin glass with a UV coating". It does make a difference - a huge one.
shinksma
