My first attempt at photo stitch.. pls C and C
pmmenon123 Hatchling 7 posts Joined Jul 2011 More info | Jul 25, 2011 13:42 | #1 |
gonzogolf dumb remark memorialized More info | Jul 25, 2011 13:51 | #2 At that size its hard to see any detail. I like the composition, but it seems to me to be overexposed or washed out in post.
argyle Cream of the Crop 8,187 posts Likes: 24 Joined Apr 2007 Location: DFW, Texas More info | Overexposed and tilted (unless my eyes are deceiving me). Suggestion for panos: shoot with the camera in the vertical (portrait) orientation. This will require a few extra frames to cover the scene, but you'll have more wiggle room at the top and bottom when cropping so as not to end up with a long, skinny image (unless that's what you're after). "Fat, drunk and stupid is no way to go through life, son". - Dean Wormer
TheeGreatPumpkin Member 42 posts Likes: 1 Joined Jul 2007 More info | Jul 25, 2011 20:21 | #4 Panos are tricky, I agree with shooting in portrait also increase your overlap to reduce stitching errors. I shoot for 20-30% overlap depending on the lens. Also check out PTGui. This software blows photoshop away. I have stitches full 360x180 degree panos with this software 200 images in all and it worked very well. My normal panos are 10 to 12 frames which this software knocks out no problem. Also, look into a leveling base or at least a hotshoe bulb to help level your shots. Good luck and have fun. And if you get real serious about it, check out the Nodel Ninja tripod mounts for panos. I have the Nodal Ninja 5 and it is absolutely necessary for large panos.
DLitton Senior Member 855 posts Likes: 2 Joined Apr 2009 Location: Atlanta, Georgia More info | Jul 25, 2011 22:52 | #5 If you shot in raw, underexpose the shots and restitch it. Straighten the horizon and then should be looking pretty good! Other than the stuff mentioned above I have nothing really to add... but if you shot it in raw you should be able to fix it easily. David
Jul 26, 2011 01:48 | #6 Thanx all..
winam Goldmember 1,942 posts Likes: 2 Joined Jul 2010 Location: Shanghai, China More info | Jul 26, 2011 08:38 | #7 I think the picture is way to bright Canon EOS 650D, Canon EOS 1000d, SIGMA DG 18-250m, Canon 18-55mm
TheeGreatPumpkin Member 42 posts Likes: 1 Joined Jul 2007 More info | Jul 27, 2011 22:01 | #8 A lot of patience and a desire to get the image the first time lol. I haven't done another one after that. It took nearly two hours to process on my i7 Mac.
| Latest registered member is IoDaLi Photography 1826 guests, 115 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
