As I have spammed through many threads
I'm torn about where to upgrade my 1d2 to: 7d, 5d2 or 1d3.
One thing I just don't get messing with the cameras I have is the tracking of objects in the AF. All the above are supposed (in servo mode) to pick up an object in the center and then follow it around as long as it doesn't leave the ellipse in the 1d series. But the 5d2 lists the same feature and for about the same area. The 7D autofocus with all cross-type points is of course different, but again it basically promises the same feature, except that in the 7D you can also pick up an object at an AF point of your choice (the others can only do the initial pickup in the center).
I can't quite believe all these cameras do it equally well. What's the scoop in practice?
How well does that work in the best of cases, anyway? What kind of object can I track? What kind of "distractions" can I have in there without losing the object? How am I supposed to know what I am focusing on since there is no indicator following the object?
