First some observations of the modifiers.
The Eli DO fabric is thin with a pebbled silver surface on the interior.
The speed ring in proprietary and it was easier to assemble than I anticipated.
The inner diffusion panel snaps into place and nearly covers to the side walls
The outer diffusion panel slips over the outer edge of the DO and is held in place with a couple of velcro patches.
The DO arrives with a deflection disk which was not used for this comparison since the lights used did not accommodate its mounting method.
The DO is 39" across and 24 inches deep.
The DO is $314.99 on Adorama's website and arrives with a nice carrying case.
To mount the DO on the Einstein I used a Kacey Enterprises Eli adapter.
The EZ Pro fabric is a bit thicker feeling and has a smooth silver interior.
The EZ Pro has an umbrella like mechanism so it opens with a simple push to lock.
The inner diffusion panel is held in place with velcro strips and there is a bout a one inch gap between the panel and the side walls
the outer diffusion panel can be set back into the octal about 3 inches to make room for a grid.
There is a grid available for the EZ Pro but its not very well made.
The EZ Pro comes with a plastic silver deflection disk that slides over the center post and can be adjusted in or out along the post.
It was not used for this comparison.
The EZ Pro is 36" across and 19" deep.
The EZ Pro is $69.00 on the Amazon's website and comes with a cheap sleeve type case.
The EZ Pro has interchangeable speedring adapters available for about $10 each. It took me about 2 minutes to change the AB adapter for the Elinchrom adapter.
The camera was a 5DII with 24-105 Zoom at 105mm. ISO 100 at F11 with 1/200 shutter to eliminate ambient influence.
I set up the test in my garage, the white ceiling is about a foot above the top of the DO and the garage door (white) is about 6 feet camera right.
The wall behind the subject is also about 6 feet away. In other words, the subject is nearly in the center of a two car garage with predominately white walls and ceiling.
Two light sources were used; an Einstein 640 and a Genesis 300B. Power was adjusted to get an F11 meter reading at the subject position.
The Macbeth gray card was used to adjust white balance and exposure. The EZ Pro octabox was appreciably bluer than the DO. I expect that is due to brightener in the diffusion panels.
I adjusted white balance and exposure, as well as not labeling the 6 test images, to encourage an objective evaluation.
I was careful to keep the light in the same position for all the shots. I changed modifiers without lowering the light. The front panel of the DO was measured to 39" from the top of the gray card. I would liked to have been able to get the subject position exactly the same for all the test images but that was a bit much to accomplish. Even so, I think this is a reasonably good comparison.
The full frame shot is to provide reference for position of gray card.
It will be interesting to see what you all think.
