Thread started 29 Jul 2011 (Friday) 15:18
Image Plane: Is it flat or an arc?
frugivore
Gallery: 11 photos
Jul 29, 2011 15:18 |  #1
I've always imagined the image plane as a giant bubble, in which the camera is located in the center and the picture captured is a section (arc) of the bubble. With a maximum aperture, the bubble would be very thin, resulting in a shallow depth of field. With a smaller aperture, the opposite.
But I am just guessing. I haven't had much luck with Google on this, so I'd really like to get some good data on this. Can anyone explain this to me or provide some links that would help?
nathancarter
Gallery: 32 photos
Jul 29, 2011 15:21 |  #2
It's a flat plane, parallel to the sensor in the body of the camera.
Take a picture of a brick wall with a very shallow DOF. The bricks in the center will be in focus, and the bricks at the edges of the frame will also be in focus. That wouldn't happen if the plane was a bubble.
Also:
http://visual-vacations.com …focus-recompose_sucks.htm (external link)
One more thing: when using a tilt-shift lens, I believe it's a flat plane that is NOT parallel to the sensor.
PixelMagic
Jul 29, 2011 15:25 |  #3
https://photography-on-the.net/forum/showthre​ad.php?t=621561
tkbslc
Jul 29, 2011 15:28 |  #4
The sensor is flat, so the image plane is supposed to flat too. But the focal plane is often less than perfectly flat on lenses.
Taylor
EOS Rp | iPhone 11 Pro Max
number ­ six
fully entitled to be jealous
Jul 29, 2011 16:22 |  #5
tkbslc wrote in post #12844607 (external link)
Yep, "supposed to be" flat. Actually, most good lenses of modern design have a pretty flat plane of focus.
To get a really flat plane of focus one would want a macro lens, which are optimized for flatness of field for photographing documents.
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
frugivore
Gallery: 11 photos
Jul 30, 2011 05:14 |  #6
So I did some more reading, and I think I had it right all along. With a simple lens, the image created on the sensor would be a parabaloid, with only the center being in focus. It is the complex lenses that make corrections for lens abberations and make the image almost flat. This article explained it very well, with lots of tests to boot:
http://toothwalker.org​/optics/astigmatism.ht​ml (external link)
chauncey
Jul 31, 2011 09:02 as a reply to  @ frugivore's post |  #7
Your initial premise is correct...yes the sensor is flat but the image plane has an arc to it, a simple tape measure with one end attached to the camera with the other end swinging in an arc will illustrate this.
Didn't ya ever wonder why one cannot buy a wider angle lens that has little distortion, see MTF Characteristics here http://www.canon-europe.com …n/ef_lens_work_​iii_en.asp (external link) and that a telephoto lens has little distortion.
That telephoto lens has a very narrow AOV as compared to the WA glass allowing for the arc of that bubble to have less of an effect on that flat sensor in the form of distortion.
frugivore
Gallery: 11 photos
Jul 31, 2011 09:52 |  #8
chauncey wrote in post #12851797 (external link)
And I would assume that in general, telephoto lenses suffer less from all other lens abberations than WA lenses. So when comparing MTF charts, one should really compare it to similar focal length and aperture lenses.
2,095 views & 0 likes for this thread, 6 members have posted to it.
1307 guests, 121 members online
