Thread started 29 Jul 2011 (Friday) 16:20
Shutter speed with AB's
Gaarryy
Jul 29, 2011 16:20 |  #1
When using AB's is the a way to get higher Shutter speed's like you can using the High speed sync with speedlights?
I'm looking to use around 1/1000th and off camera flash. I'm not sure if I should just borrow a few 580exII's or borrow an AB800.
what I want to try makes sense in my head but I'm not sure how I'd do it. I"m playing around with some sports action shots
thanks
---------------Camera, Lens, Flash stuff.. but still wanting more
sigma ­ pi
Jul 29, 2011 16:24 |  #2
Gaarryy wrote in post #12844861 (external link)
thanks
Flash freezes action not the shutter.
Don't try to confuse me with the facts, my mind is already made up.
http://www.flickr.com …6850267535/in/p​hotostream (external link)
Gaarryy
Jul 29, 2011 16:38 |  #3
thanks
1/200th isn't doing it,, ,still blurring...
sigma ­ pi
Jul 29, 2011 16:47 |  #4
Gaarryy wrote in post #12844947 (external link)
thanks
Then the problem is flash duration. How bad is it?
dedsen
Jul 29, 2011 16:51 |  #5
thanks
That's not going to happen. Even with Canon flashes and HSS enabled you are going to get blur. The trick to stopping motion with flash and slow shutter speed is to get the flash bright enough that the ambient is 2 or 3 stops darker than the flash.
FlashZebra
This space available
Jul 29, 2011 16:51 |  #6
thanks
Indicate what you are photographing and likely more important the ambient light conditions where the flash is being used.
Enjoy! Lon
Curtis ­ N
Master Flasher
Jul 29, 2011 16:51 |  #7
X-sync speed is a limitation of the camera's shutter. More info in Chapter 4:
https://photography-on-the.net/forum/showthre​ad.php?t=208520
Studio strobes are not capable of high speed sync, which is actually a series of small bursts of flash at a high frequency during the entire duration of shutter curtain movement.
Since the flash duration of Alienbees is shortest at high power, the way to minimize motion blur is to set them at high power and adjust your aperture accordingly.
Thyristor controlled hotshoe flash units have a shorter flash duration at lower power settings. They are much better suited to stopping motion. A hotshoe flash at low power will be much more effective than HSS with a fast shutter speed.
Gaarryy
Jul 29, 2011 17:04 |  #8
dedsen wrote in post #12845007 (external link)
Hmm I think that's what I"m attempting to do, when I was taking my test pics without flash, I was not quite One& 1/2 stops darker. I was thinking, and I admit I might be wrong in how I"m thinking, that when I was using the HSS the flash power was going to be quite a bit less powerful so I couldn't set my exposure to the 2 to 3 stop range.
So I figured I could just borrow a couple 580's from a friend. Then I started thinking {big mistake :) } that maybe using an AB would work instead of using multi speedlights. But I honestly don't know a lot about them power wise,, Just that a friend has recently gotten one and I could borrow it.
? didn't think 1/1000th was considered slow though. typo?? :)
Gaarryy
Jul 29, 2011 17:05 |  #9
Curtis N wrote in post #12845010 (external link)
thanks Curtis.. very good info
Gaarryy
Jul 29, 2011 17:10 |  #10
FlashZebra wrote in post #12845009 (external link)
Enjoy! Lon
Track and Field shots about an hour before sunset. Using the sun to back light and flash at an angle to light up faces, & front side.
I think I was at 100iso, Apature 4 and under but mostly 2.8-3.2 , shutter at 1/500 to 1/800 trying HSS
kenyee
Jul 29, 2011 17:44 |  #11
Pocketwizard TT is probably what you want...
Pentax K20D, 77Ltd, 43Ltd, Sigma 17-70, 60-250/4, crapload of Strobist gear (SB28's, RP JrX Studios, Einsteins, WL, Speedo BD, softboxes, grids, etc.)
bobbyz
Jul 29, 2011 18:28 |  #12
Gaarryy wrote in post #12845096 (external link)
So what is the problem? Why not post sample shot to make it easier.
Fuji XT-1, 18-55mm
Curtis ­ N
Master Flasher
Jul 29, 2011 21:08 |  #13
At an angle? Outdoors? Huh?
bobbyz
Jul 29, 2011 21:11 |  #14
Curtis N wrote in post #12846109 (external link)
he probably means sun as back/rim light and then his Ab strobe at an angle to the subject for his main light.
Fuji XT-1, 18-55mm
Tim ­ S
Jul 29, 2011 22:24 |  #15
thanks
Too much ambient and/or flash duration....
Samples?
Tim
Equipment
3,029 views & 0 likes for this thread, 12 members have posted to it.
1452 guests, 137 members online
