When I started doing table-top photography with my Canon Powershot G2 and 420EX flash, I needed a way to modify the lighting to give me the effect of at least two light sources and also needed to soften the light. I dreamed up the idea of a pair of portable reflectors and built them. The photos here are of one of the reflectors.
What you see is a cheapie light stand which could be duplicated with 2x2 lumber and a 3/8" diameter rod, an adjustable arm that I built from wood and common hardware, a holder for the reflector with kitchen clips to mount the reflector, and an automotive window shade for the reflector itself. I also used foamcore for a less harsh reflection. Hopefully the photos have enough detail for you to understand the construction. If not, ask and I shall provide more information and/or more closeup photos.
The beauty of this holder is that the reflector can be put into virtually any position you can think of. I still use these in conjunction with all my other lighting equipment.
