phreeky wrote in post #12860292
Give the nurse the P&S, leave the DSLR at home, and enjoy the moment.
yeah, i thought of using a tripod, mount a vid camera on it, i use a prime lens, nurse uses the p&s as well.
Keyan wrote in post #12860316
I used a 50mm 1.4 and my Speedlight with a diffuser and bounce. It won't hurt the baby unless you like fire it off point blank 100 times in their face. I didn't get the camera out till after the baby was born and things had settled down a bit. You are going to be there for a day or two, so taking the big camera is not a bad idea.
The 50L..meh. I'd rather save nearly a grand and get the 1.4. Or even the 1.8.
i already made a thread on that one, and i think i'm going with the 50L (at least that's until the subsconcious debate heats up again)
JeffreyG wrote in post #12860324
I think the 17-40, 35L and Speedlight you have should be sufficient. The main point is to take a few shots and document the event I'd say.
shhhh. i HAVE to buy something for the DR
I would not worry overmuch about trying to not use flash. It's not going to hurt the baby, and will only become a problem if you are possessed of an urge to take a few dozen shots. At that point the flash might start to bother the nurses and mother.
So use 35L for the first moment in available light (see example - I was so distracted when I took this shot I failed to notice I was at ISO200 and 1/13 but it's a keeper
to me.) and then consider the 17-40 for those first key moments like weighing and cleaning off. You also might find the light on the warming table is enough to work fine at f/4 with a 5D2 and the flash is still not needed there.
The second shot is just to show you what the room looked like to the eye. You can see by the brightness behind the midwife that the rest of the room is pretty dim at f/2.8, ISO800 and 1/40. The places where the staff work like the countertop and the warming table will be well lit.
yeah, that would work. what do you guys think about the macro lens? hands and feet tight shots? or should i wait for the baby to be clean already (next day) before i take those?
