Thread started 01 Aug 2011 (Monday) 22:49
pink at high iso's
john_galt
Joined Mar 2011
Aug 01, 2011 22:49 |  #1
i was just reading some threads and stumbled upon someone seeing pink spots on the bottom of the frame on their 5d ii at high iso. so i looked at a couple shots of my own i took at 25600 iso to see if i noticed it, and it looks like i see the pink at the bottom right mentioned. is this normal at high iso? or is this something canon will fix? these shots are sooc, i adjusted the exposure on one but the pink was still there prior to that. the sky had some pink to it that evening, so that may be normal. just more concerned with the pink on the bottom right of the frame. appreciate any input.
IMAGE: http://farm7.static.flickr.com/6142/6000254551_ef710ee4f4_b.jpg
IMAGE: http://farm7.static.flickr.com/6137/6000803506_3b46cff488_b.jpg
searched and it looked like someone else had this also. anyone else have this and send back to canon?
https://photography-on-the.net …9&highlight=pin​k+at+25600
Gear: 5d iii, 17-40mm l, 24-70mm ii, 35mm 1.4 l, 50mm 1.4, 85mm 1.8, 135mm l, 70-200mm ii l, 600ex-rt
cedew
Aug 01, 2011 23:01 |  #2
That would probably bug me too, but I'd try real hard to ignore it because I know that it would never be a problem in any of my real world shooting.
robbug
Aug 01, 2011 23:20 as a reply to  @ cedew's post |  #3
Yes, those spots are normal. When using hi ISO such as your example you literally are "overcharging" your sensor to make it very sensitive. Each sensor point is scrambling for information and if it doesn't get any fast enough it begins to make up its own information. Hence noise. Areas around the edges tend to heat at different rates and as the heat goes up so does the noise. This is a tough situation for long exposure photography or high iso photography. This phenomena exists across all CCDs and is particularly a PITA for astronomers who end up "icing" their specialized cameras.
Kinda like kicking up the speed of a conveyor belt. There is a lot of information out there on how CMOS sensors work. The more you know about it and how it reacts under certain conditions, the more you will know how to push your camera to it's limits.
Edit: The example link you posted appears a bit more extreme and appears to be more of a sensor issue. Corner areas are notorious for generating more noise. If I saw a band across my sensor I would be more concerned not for high iso situations but for potential hot pixel generation.
Refractive Photos (external link)
Stuff that gets me the exposure
When asked if there were too many people taking pictures today, Elliot Erwitt replied, "All you need is a pencil and a piece of paper to write a novel, don't you?"
NinetyEight
"Banned for life"
Aug 02, 2011 01:45 |  #4
Does the camera function properly in 'normal' use at 'normal' ISO values. It looks like you are trying to find a problem that you have read about, just because you can...
Do you use this high an ISO normally?
Kev
john_galt
Joined Mar 2011
Aug 02, 2011 05:38 |  #5
NinetyEight wrote in post #12861820 (external link)
i do not normally bit when i do, id prefer not to see any pink if possible. if its normal, i can probably live with it. i havent noticed any hot pixels though. its still under warranty so wanted to know if its something to send it in for before it expires
Wide ­ Boy
Joined May 2011
Aug 02, 2011 06:07 as a reply to  @ john_galt's post |  #6
Keep looking, I am sure you will find that hot pixel, it's bound to be in there somewhere!!!!
Sony A7 | 28-70 | Tamron 15-30 (Canon fit)
550D with a battery grip | Canon 70-200mm F4L | Canon 50mm 1.8mkII | Canon EF-S 18-55mm f/3.5-5.6 IS | YN 460II |
Nikon D7000 | 18-55 G VR | Tokina 11-16 2.8
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Aug 02, 2011 07:28 |  #7
One of the 3 I had was so bad, you could see impacts at ISO 1600. It was faint and would appear only in certain exposures, but it was there, and the corner got brighter each level up. Other areas were blotchy as well. I sent it in, they seem to make it better, in the end, it went to a new owner that didn't shoot high ISO. Some units have this worse than others, I think it must have something to do with the sensors themselves due to the variances from one to another. The last one I had didn't really show this at all. My 1D4 has it as well. :(
NinetyEight
"Banned for life"
Aug 02, 2011 11:04 |  #8
john_galt wrote in post #12862314 (external link)
It wouldn't hurt to send it in, but if you only use it for the odd shot and don't usually have an issue with it you may wish to put up with it rather than lose the camera for a week or so.
I assume that ISO25600 on the 5D is one of the expanded ones in software? This could be a 'feature' of the way the software works?
TeamSpeed wrote in post #12862511 (external link)
If it's coming in at ISO1600 then there is a problem but if was just at the very high (25600 fir instance) this could just be a trade-off of having such high ISO's available. Sounds like it's a bit of a design 'feature' if its affecting your 1D as well :(
Kev
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Aug 02, 2011 11:28 |  #9
NinetyEight wrote in post #12863645 (external link)
I think you will see this on many bodies actually and not just at 25600. Just taking a test shot in a dark room with the body cap on at ISO 3200, 6400, and 12800 will show this "noise", if the camera has an issue. It just goes up in intensity as you move higher in the ISO range. It is consistently along the bottom edge and right corner though, in the different units I have seen this on. You just learn to live with it, I believe.
Here is a 6400 lens-cap dark-room sample from the one I sent in. Sure I auto-leveled to make the noise much worse than it was, but it still very blotchy noise that has impacts on IQ. At 1600, I could just make out a bit of pink in the lower corner in some pictures that had darker exposures.
IMAGE: http://teamspeed.smugmug.com/Electronics/Miscellaneous-Items/IMG4430a/1076187498_72EBs-M.jpg
This pattern was consistent at 3200, 6400, 12800 and 25600, it just varied with intensity. I think it is a sensor thing. The 1D doesn't have this bad of a blotchy appearance, and the pink is more uniform at the bottom of the frame, and not concentrated in the corner as much. The last 5D2 I had showed very little of any of this.
Dooms_day
Aug 02, 2011 13:06 |  #10
The 5d2's true max iso is 6400 I believe, so when you take the picture it underexposes and then boosts in 2 stops before saving. I would recommend longer exposures (much longer) at low iso's because you are on a tripod and taking a picture of a still city, would look tons better with no noise I agree, but sending it back wont do anything, it's the fact that the sensors they put in are not good enough.
Canon EOS-1D mk ii + 70-200 4.0 USM L + Sigma 28-70mm 2.8-4 + Nifty 50
500px (external link) - Google+ (external link)
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Aug 02, 2011 14:42 |  #11
Dooms_day wrote in post #12864345 (external link)
I beg to differ, they are good enough, like I said, I had enough samples to see a large variance in performance. There are some that won't show this, or very, very minimally. I don't see this on my 7D at all, for example, but do on the 1D4. And sending it back did improve the overall issue a little (they did some wb changes?), but it still didn't please me.
john_galt
Joined Mar 2011
Aug 02, 2011 21:51 |  #12
thx all. i think i can live w/ this then rather than send it in and gamble if it'll get fixed. sounds like it'll be a hit or miss type thing. only happens on the expansion h2 h1 iso's for me so not too bad.
1,951 views & 0 likes for this thread, 7 members have posted to it.
pink at high iso's
1091 guests, 149 members online
