while looking for some info on a totally different subject I stumbled on to what's called a four square with softbox from { www.lightwaredirect.com
After a quick search on here the only threads I found on it were more talking about the techniques the person was using and not on the actual equiptment itself. exp 8 spedlights for HSS shooting
So I'm wondering has anyone used the four square block and any of the soft boxes. while I doubt I'd use it to go out and buy four 580ex's to use. But since I already have a couple of flashes and can borrow a couple others when needed I'm more curious about how sturdy it is and do the softboxes actually work well? as opposed to making or buying something that holds only 2-3 flashes
} in my case where I already have 3-4 speedlights, it looks like a simple way to use them all at once for less money than an AB/power pack combo, most of the brackets I'm seen for multiple speedlights don't have a softbox that fits well.. that's what I was curious about. If you already have the speedlights, what is the quality of the softbox and how well it works.
