Thread started 05 Aug 2011 (Friday) 18:55
AF Microadjust... where have you been all my life?
HansSteinert
Aug 05, 2011 18:55 |  #1
I just upgraded from a 60D to a 5D II, and decided to try out the new MA ability.
I own 5 lenses. 3 of them are Canon L. 2 of them are Sigma primes.
I found that all my my lenses, except for my Canon 100mm f2.8L lens, had significant sharpness improvements once I added certain amounts of MA. Optimized values varied between -8 and +15 (believe it or not, the Sigma wasn't the one that needed +15).
This is an incredibly useful tool, and quite honestly, I think most copies of all lenses will benefit from it, at least slightly. I'm beginning to think it's sheer luck if a lens matches your camera perfectly, and most of the time they will be slightly off due to inherent manufacturing tolerance variance. Hence why MA is so damn important.
Why is this feature not available in all DSLR cameras?!?!?!?!?!?!?!
Carlwashere
Joined May 2011
Aug 05, 2011 19:56 |  #2
You gotta pay for it. :)
Apparently it's really hard to put it in lower-end cameras, but I kind of doubt that...
-Canon T2i- -Tammy 17-50 non-VC- -50 f1.4- -100 f2.8 macro- -85 f1.8-
-Pentax SP1000- -SMC Takumar 55 f2- -Takumar 28 f3.5- -Vivitar 135 f2.8-
HansSteinert
Aug 05, 2011 19:57 |  #3
Carlwashere wrote in post #12884843 (external link)
bullsh*t, it's just software.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Aug 05, 2011 19:59 |  #4
Why don't two different GM vehicles that share an LS2 motor run even remotely close 1/4 mile times? Because features are things that you pay for, and even though the timing and fuel maps are just software tables, you have to pay to get the upgrades.
This feature is useful, however, it has some shortcomings. You just haven't hit them yet. Give it time... :)
v_lestat
Aug 05, 2011 20:10 |  #5
HansSteinert wrote in post #12884603 (external link)
if you have that many lenses that need THAT much adjustment i would be taking your 5D back to the store you got it from and asking them if you can try a different body in the store to see if it needs the same adjustments.
there is no way that you should be going from a 60D where all lenses were potentially are ok, to a 5D MKII and they need that much adjustment. its just not going to happen without the 5D body being completely out of wack.
do NOT sit on your fanny and just accept a body that requires all lenses to be MA,, thats just total 100% bullcrap no matter who made it.
and MA has its short comings is an understatement. it rarely works because neither the lens nor the body can misfocus equally every shot, its just not possible because of focal distances.
plus different fstops can throw off the MA also.
even canon themselves strictly say that if using MA, the lens/body should be adjusted before each shoot because MA is not a constant variable.
anyways, MA is a broken attempt to cover up canon's half arsed quality control and an excuse to get away with murder when it comes to focus calibration.
nearly every non L lens i have owed has had to be sent in for calibration and came back dead on. i have had 2x 50D's that also needed it, where MA just never worked.. period.
after United Camera got thru with them they were dead on accurate, both lenses and camera bodies where sending them to canon was a nightmare and took 2-3 trips every time to get it right.
i have a 50 1.4 i sent in for wacko front and back focusing, and now... it 100% back focuses every single picture... thanks canon.. you guys would F up a wet dream.
i would love to see a side by side with MA turned off to see what the difference is.
this again would, or could potential prove the point that the body is faulty, not the lenses.
HansSteinert
Aug 05, 2011 20:20 |  #6
oh.
That sucks.
It seemed consistent when I was shooting with it earlier after I used MA.
TeamSpeed, what kind of short comings?
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Aug 05, 2011 20:36 |  #7
HansSteinert wrote in post #12884916 (external link)
oh.
That sucks.
Since there is one single value for a lens, you may find that some zooms will actually require a different value at the wide end vs the zoom end. Also, some people have found that some lenses, even primes, require a different value simply based on subject distance. So while it certainly has its merits, it is not a cure-all.
sharrowm
Joined Jun 2005
Aug 05, 2011 20:47 |  #8
Wow, all but 1 of my lenses was dead on! I'm going to go buy a lottery ticket! :)
Marc
5D Mark II | 7D |17-40L | 24-105L IS| 70-200L 4.0 IS | 50 1.8 | 100mm macro|100-400L | 580EX
It never looks the same on the wall as it does in the paint can
HansSteinert
Aug 05, 2011 20:49 |  #9
If focus changes at different apertures, aren't we screwed regardless of MA?
sharrowm
Joined Jun 2005
Aug 05, 2011 20:59 |  #10
HansSteinert wrote in post #12885026 (external link)
In the manuals for both of my MFA cameras (7D and 5DII) canon seems to be trying to discourage people from using this function. Basically saying "use as last resort" (I am away from home and don't have the manuals with me at present so I don't have the exact verbiage). I am sure Canon had a good reason for this. My guess is that there are too many variables involved for the casual user to use MFA effectively.
Marc
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Aug 05, 2011 20:59 |  #11
Remember that each single value of MFA equates to 1/8 of your DOF. This is quite small. Couple that with the sickness to 100% pixel peep, and you get the complaints. :)
HansSteinert
Aug 05, 2011 23:47 |  #12
I based my MA off shooting at a box. I decided to bust out the focusing charts a little bit ago.
My Sigma 50mm is front focusing like no other.
And I saw that my Sigma 50mm is front focusing like a b*tch on it:
Sigma 50mm f1.4 AF:
How I can get it when I manual focus it:
Should I fix it with MA or should I send it in?
I'll probably post results of my other lenses too once I get them done.
HansSteinert
Aug 06, 2011 01:52 |  #13
So my 50mm requires an MA of 20...
should I send it in, or just live with MA 20? Is there any downside to MA 20?
ninetwentynine
Aug 06, 2011 03:42 as a reply to  @ HansSteinert's post |  #14
^ if you're still under warranty, i'd just send it in.
LeeRatters
Aug 06, 2011 05:06 |  #15
v_lestat wrote in post #12884889 (external link)
^^^ That makes you sound like you ain't much of a Canon fan .... :lol: :lol:
The OP's MA adjustments goes from -8 to +15 - surely if it was the body out of whack all the lenses would need very similar MA right? Or not?
>> Flickr << (external link)
>> Instagram<< (external link)
4,479 views & 0 likes for this thread, 15 members have posted to it.
569 guests, 135 members online
