Thread started 06 Aug 2011 (Saturday) 16:57
Canon S95: Custom/"Special" Setting?
tuttifrutti
Gallery: 13 photos
Aug 06, 2011 16:57 |  #1
Hi folks,
Can anyone tell me if i can save a particular set of settings (maybe on the "C" button on the top wheel).
What i've after is being able to save for instance F5/6, ISO100 and a flash setting all together so I can just turn the wheel and go with it.
Also wondering what's the best flash setting I can get from the S95 for taking images of my fish in the dark and cutting back on the amount of flash showing on the fish's flank (see example). I don't know if this is possible to get better though as I need to be close to the fish with the tripod to get as clear a picture as I can noise-wise etc.
Thanks all in advance for your help.
Hello...
My name's Ian and i'm a photography junkie :rolleyes:
tmwag
Brown Noser has crush on Suzyview
Aug 06, 2011 17:29 |  #2
Should be able to save custom settings. I think it's covered in the manual...
As far as the flash have you tried the 'slow sync' function? It uses a slow shutter speed (tripod needed). Might work well for the night carp shot...nice carp btw
PaulRivers
Aug 08, 2011 14:21 |  #3
Yes you can save specific settings to the "C" mode on the dial. You can save P, TV, AV, M...I think that covers it. You just set up the mode like you want to save it, then do Menu->Save Settings (I think it's the bottom menu item) and then when you switch to C mode all you stuff you saved including the mode will pop up.
C mode works differently than the other modes - you can change what you want, but if you turn the camera off and then on (or switch modes), unlike the other modes, it will forget your changed settings and go back to the settings you set when you did Menu->Save Settings.
On mine, I have C set to the following -
P mode
Flash - On
Iso - 80
AF Frame - Face AiAF (it's the first item under Menu, it helps keeps peoples faces from getting blown out by the flash)
Not that all these settings would necessarily help with your fish pics though. I mean - iso80 results in a sharper, cleaner picture - but it also results in a dark background, and more importantly turns up the flash power so it's just going to make the amount of flash shown on the fish higher.
There's 2 ways to get the flash power lower -
1. Use a higher iso (but then the pic ends up noisier and less clean)
2. Use a longer shutter speed...if the camera is on a tripod that's ok for the camera, but it depends on how steady you can stay yourself, and whether the fish moves.
If you want to eliminate the flash reflection, that done by "bouncing" the flash or by using an external flash and a flash umbrella - unfortunately I doubt either of these techniques would be useful for you. You can use a sort of external flash and bounce it on the s95 -
http://forums.dpreview​.com …age=36183658&ch​angemode=1 (external link)
But you need one of two things -
1. A large white surface nearby to bounce it off of. Indoors a lot of times a wall or ceiling does this...outdoors it seems highly unlikely something like this will be around.
2. Or bring your own large white surface - a flash umbrella. However, if you want to save time I don't think setting one of those up will be within your time/hassle limits.
To be honest I think the picture you have above is pretty decent. :-)
tuttifrutti
Gallery: 13 photos
Aug 08, 2011 15:39 |  #4
Thanks so much for your replies and help... all very much appreciated - that looks like exactly what I was after
Hello...
stealthdave
Joined Mar 2011
Aug 09, 2011 07:34 as a reply to  @ tuttifrutti's post |  #5
I read somewhere that dropping the flash exposure by 2/3rds is good, I have it set like that on mine with -1/3 exposure compoensation and it takes good flash shots.
3,874 views & 0 likes for this thread, 4 members have posted to it.
1059 guests, 115 members online
