When to use evaluative over spot metering? Would spot metering suit portraits where evaluative be more for landscape type shots?
fitshaced Senior Member 442 posts Joined Jul 2011 More info | Aug 06, 2011 22:39 | #1 When to use evaluative over spot metering? Would spot metering suit portraits where evaluative be more for landscape type shots? http://www.flickr.com/photos/picsbykev/
HaroldC3 Goldmember More info | Aug 06, 2011 22:55 | #2 http://www.photozone.de/Technique
Shoal Member 73 posts Joined Jul 2011 More info | Aug 06, 2011 23:04 | #3 Some people use off camera meters which is more of a manual way to go about it from what I understand. I have not tried yet. I try various metering modes but generally go with evaluative I think it is set on. I shoot mostly in manual mode, so from what I understand (and please do correct me if I am wrong), this means that I don't really depend on the metering mode when shooting in manual.
anthony11 Goldmember 2,148 posts Joined Mar 2009 More info | Aug 07, 2011 03:57 | #4 Permanentlyfitshaced wrote in post #12889899 When to use evaluative over spot metering? Would spot metering suit portraits where evaluative be more for landscape type shots? My understanding of spot metering is that it's useful when there's a very large difference in brightness between foreground and background, eg. daylight interior with the subject in front of a window. Evaluative would be influenced by the bg and underexpose the subject. Switching to spot allows one to disregard the bg, but it's also possible to meter from too small an area, and still get bad results -- the center-weighted and partial modes sometimes work better. 5D2, 24-105L, 85mm f/1.8, MP960, HG21, crumbling G6+R72, Brownian toddler
yogestee "my posts can be a little colourful" More info | Aug 07, 2011 04:51 | #5 fitshaced wrote in post #12889899 When to use evaluative over spot metering? Would spot metering suit portraits where evaluative be more for landscape type shots? Not always as skin tones are different depending on the ethnicity of the subject.. Jurgen
SteveofCornubia Senior Member 459 posts Joined Oct 2010 Location: Oztralia More info | If in doubt, get the grey card out! 5D MK3, 7D, 70-200mm f/2.8L IS II, 24-70mm f/2.8L, 16-35mm f/2.8L, EF 1.4x TC MKIII, Nissin Di866 II, Nissin Di466
yogestee "my posts can be a little colourful" More info | Aug 07, 2011 04:58 | #7 Steve of Cornubia wrote in post #12890726 If in doubt, get the grey card out! Or use a hand held meter in incident mode. Jurgen
SteveofCornubia Senior Member 459 posts Joined Oct 2010 Location: Oztralia More info | Aug 07, 2011 05:00 | #8 yogestee wrote in post #12890730 Or use a hand held meter in incident mode. But that doesn't rhyme. 5D MK3, 7D, 70-200mm f/2.8L IS II, 24-70mm f/2.8L, 16-35mm f/2.8L, EF 1.4x TC MKIII, Nissin Di866 II, Nissin Di466
Hogloff Cream of the Crop 7,606 posts Likes: 416 Joined Apr 2003 Location: British Columbia More info | Aug 07, 2011 05:11 | #9 Permanent banyogestee wrote in post #12890721 Not always as skin tones are different depending on the ethnicity of the subject.. With spot metering, the camera's meter will place the subject's skin tone at 18% reflectance grey, meaning that all skin tones will have the same tonality.. Yes, but you can then compensate your exposure for the varying darkness of skin.
Aug 07, 2011 05:12 | #10 Whatever mode you need to understand what is happening and when to overrule it. Here's an example where evaluative (left) knocks the socks off spot (right). The spot metering has decided that the box should be grey, so everything is underexposed. Evaluative metering has overruled that decision and tried to get the background exposed corrrectly. If you were using spot metering for this you'd have to know to dial in some exposure compensation. Frank Hollis - Retired mass spectroscopist
yogestee "my posts can be a little colourful" More info | Aug 07, 2011 05:35 | #11 hollis_f wrote in post #12890758 Whatever mode you need to understand what is happening and when to overrule it. Here's an example where evaluative (left) knocks the socks off spot (right). The spot metering has decided that the box should be grey, so everything is underexposed. Evaluative metering has overruled that decision and tried to get the background exposed corrrectly. If you were using spot metering for this you'd have to know to dial in some exposure compensation. ![]() This is what I'm talking about in my post.. Jurgen
Aug 07, 2011 06:03 | #12 This is actually a big lesson for me, even if it seems simple. I think I've been using spot metering incorrectly and, because of this, suffering poorly exposed shots. Thanks for the tips guys. Going to read up some more on this. http://www.flickr.com/photos/picsbykev/
wfarrell4 Goldmember 2,551 posts Likes: 1 Joined Jun 2011 Location: NJ More info | Aug 07, 2011 06:28 | #13 Permanent banI spot meter the highlights I want to keep @ +2 stops....almost guaranteed an ETTR histogram. Will: flickr
Hogloff Cream of the Crop 7,606 posts Likes: 416 Joined Apr 2003 Location: British Columbia More info | Aug 07, 2011 09:08 | #14 Permanent banhollis_f wrote in post #12890758 Whatever mode you need to understand what is happening and when to overrule it. Here's an example where evaluative (left) knocks the socks off spot (right). The spot metering has decided that the box should be grey, so everything is underexposed. Evaluative metering has overruled that decision and tried to get the background exposed corrrectly. If you were using spot metering for this you'd have to know to dial in some exposure compensation. ![]() Yes, evaluative metering will do an OK job some of the time, but in dramatic lighting it will fail you. Get used to spot metering, know when to compensate and take the decision away from the camera and put control into your own hands.
ONE30 I don't have a point!!! 4,284 posts Likes: 1560 Joined Mar 2011 Location: newYORK More info | Aug 07, 2011 12:39 | #15 fitshaced wrote in post #12889899 When to use evaluative over spot metering? Would spot metering suit portraits where evaluative be more for landscape type shots? check out this LINK
| Latest registered member is semonsters 999 guests, 110 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
