Thread started 07 Aug 2011 (Sunday) 03:27
Help.. how to fix my 480EXII?
EOS ­ mE
Aug 07, 2011 03:27 |  #1
it's been a while since i last used my 430EX and just when i decided to use it tonight, it felt very heavy; which is not good.
yup, kirkland batteries are still in there and it leaked! one of the contact pads on the battery cover got the hit.
what should i do to fix this? is there a solution i can use?
thanks in advance.
See Sample Here (external link)
5DMKII Gripped | 30D Gripped | 50mm f1.4 | 24-70mm f2.8L | 70-200mm f2.8L IS | 430EX | 580EXIIhttps://photography-on-the.net/forum/showthre​ad.php?t=416554
My Reviews:
KATA 3N1 - 25PL Bag, Dolica CF Tripod ZX600B103
David ­ Rossberg
Aug 07, 2011 06:33 |  #2
This is easily fixed with a glassfibre pen;
http://www.radioshack.​com …dex.jsp?product​Id=3998315 (external link)
Best regards,
/David
Treat your friends as you do your pictures, and place them in their best light.
- Jennie Jerome Churchill
EOS ­ mE
Aug 07, 2011 11:01 |  #3
thanks David.. besides this pen, are there any other solution based type that would work or would that be a bad idea? cuz i was thinking isn't this like the same corrosion found on the terminal part of the car battery?
My Reviews:
DarenM
Aug 07, 2011 11:04 |  #4
I wouldnt think you would want to use any liquid solution. another possibility is to scrape off the majority of the corrosion with a pen knife and then use a pencil eraser (yes they still make pencils) to do final cleaning
Canon 1D MK IV, Canon 1D MK III, Canon 5D, 24-70 2.8L, 70-200 2.8 L IS MK II, 17-40 F4 Canon, 430 EX, Canon A2E, 530EX Canon 1.4 Extender, 580 II, 600EX-RT, ST-E3-RT, (Way too much stuff for an amateur)
MSIGuy
Aug 07, 2011 11:57 |  #5
Make a paste of baking soda and water, then brush it on the corrosion with an old tooth brush. It'll come right off.
Some cameras, some lenses, plenty of gaffer's tape and beer.
Curtis ­ N
Master Flasher
Aug 07, 2011 20:44 |  #6
MSIGuy wrote in post #12891812 (external link)
Yep.
digger58
Aug 07, 2011 20:53 |  #7
I had a very similar situation a while back, did a bit of research and found an idea that worked like a dream for me.
Take an ordinary pencil with an eraser on it and use the eraser to clean up the corosion.
Before you try anything else, give it a shot, you wil be surprised
5D mkii
50D
7D
A bunch of glass and very limited knowledge
EOS ­ mE
Aug 07, 2011 23:46 |  #8
thx guys.. will give it a try. going to canada next week and thinking about bring the 430EX instead of the 580EX2 to go with my 5D2 + 24-105L
My Reviews:
DarenM
Aug 11, 2011 17:13 |  #9
digger58 wrote in post #12894191 (external link)
agree
LONDON808
Aug 11, 2011 17:26 |  #10
bakeing soda and coke works better then water
View My Flickr (external link)
EOS ­ mE
Aug 12, 2011 00:52 |  #11
well, i tried some micro thin sandpaper and it seems the connection is back on ok. but will spend more time cleaning it later. tried using the pencil eraser and that helped a bit too. it seems the connector is a bit oxidized.
My Reviews:
DarenM
Aug 14, 2011 10:37 as a reply to  @ EOS mE's post |  #12
FYI, i have a habit of using the pencil eraser on the contacts on the camera itself as well..
DarenM
Aug 14, 2011 10:37 as a reply to  @ EOS mE's post |  #13
FYI, i have a habit of using the pencil eraser on the contacts on the camera itself as well..hot she contacts that is
Andrew_WOT
Aug 14, 2011 12:45 |  #14
DarenM wrote in post #12932848 (external link)
Very bad idea on plated contacts.
3,608 views & 0 likes for this thread, 8 members have posted to it.
1384 guests, 120 members online
