Thread started 07 Aug 2011 (Sunday) 11:13
Focussing technique for portraits & group pics
ssmanak
Joined Jun 2010
Aug 07, 2011 11:13 |  #1
My question below is when I use my 24-70 for portraits / group pictures -- with 3 to 12 feet distance and typical 2.8 to 4 apperture (with lens wide open accuracy of focus becomes important due thin DOF).
Which technique from two below will give me better acuracy:
1. Use only centre focus point, focus on eye/face and then recompose.
2. Select focus point nearest to face (top point). Focus this point on face, do minor recompose.
3. Use all nine focus points. Let camera decide - Take pic if it has focussed some where on body.
If this question has been addressed in some other place, kindly give me link. Thanks for help.
ss.manak
EOS 6D ii, Canon 24-105f4 L ii, Canon 50 f1.4, Tamron 100-400 f4.5-6.3 VC, Canon 430EX ii, Canon 270 exii
CameraMan
Gallery: 28 photos
Aug 07, 2011 11:19 |  #2
No to #3. It will pick what it thinks is the best focal point.
I usually keep it on the center focus point, aim for the eyes and recompose. I've tried using your 2nd option but I found myself readjusting the focal point very often and it was a pain in the rump.
Photographer (external link) | The Toys! | Video (external link) | Flickr (external link)
Shampoo sounds like an unfortunate name for a hair product.
You're a ghost driving a meat-coated skeleton made from stardust, riding a rock, hurtling through space. Fear Nothing!
davidc502
Aug 07, 2011 11:32 |  #3
ssmanak wrote in post #12891644 (external link)
It's amazing you asked this question.... Will have to search, but someone posted a really good article about typical focusing errors. It's pretty advanced stuff, so I'll dig around for it and post.
From memory if one uses the center focus point and recomposes, it's almost guaranteed to be back focused.
_
My Gear is ---> Here
davidc502
Aug 07, 2011 11:46 |  #4
Here is the article..... Some really good pointers below.
http://visual-vacations.com …focus-recompose_sucks.htm (external link)
_
mrgooch
Gallery: 29 photos
Aug 07, 2011 11:46 |  #5
You should be aware of the depth of field the f stop will give you. Using f5.6-f8 is more advised for groups.
john_galt
Joined Mar 2011
Aug 07, 2011 11:54 |  #6
mrgooch wrote in post #12891765 (external link)
agree, stopping down will give you more depth of field and a little more room if focus/recomposing, depending on distance/subject distance, and all that good stuff.
checkout the DOF calculator and input your variables
http://www.dofmaster.c​om/dofjs.html (external link)
Gear: 5d iii, 17-40mm l, 24-70mm ii, 35mm 1.4 l, 50mm 1.4, 85mm 1.8, 135mm l, 70-200mm ii l, 600ex-rt
CameraMan
Gallery: 28 photos
Aug 07, 2011 11:56 |  #7
Interesting article but I never had the problem with back focusing when I use center focus and recompose. Maybe that technique needs to be mastered. Recomposing involves minor movement of the focal plane and I don't think it affects the photo much. however, I'm not totally alienating option #2. It just requires more adjusting in camera before each shot. Both #1 & #2 are good techniques.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Aug 07, 2011 11:58 |  #8
davidc502 wrote in post #12891763 (external link)
CameraMan wrote in post #12891810 (external link)
Correct Cameraman, that article is inaccurate, as you can see from the tests I posted in the recent post on this. I show the most obscene amount of recomposure, from one corner to the other. It shows when somebody has a theory and posts it as fact, however in real-world shooting, you can see it is not that big a deal, or a complete non-factor.
https://photography-on-the.net …p?p=12888366#po​st12888366
To answer the OP, #2 is best, then #1.
pulsar123
Gallery: 82 photos
Aug 07, 2011 13:15 |  #9
As long as you pick correct (big enough) DoF, you'll never have issues with focus/recompose technique - at least for portraits (the situation will be different for macro shots).
6D (normal), 6D (full spectrum), Tamron 24-70 f2.8 VC, 135L, 70-200 f4L, 50mm f1.8 STM, Samyang 8mm fisheye, home studio, Fast Stacker
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Aug 07, 2011 15:06 |  #10
pulsar123 wrote in post #12892188 (external link)
Again, I did a macro sample where the DOF is less than 1 inch. I focused in the upper left corner, took a shot, then recomposed the subject to the lower right corner.
maryhee
Aug 07, 2011 15:10 |  #11
subscribing.
mary
7D flickr (external link)
Ziffle
Aug 07, 2011 16:37 |  #12
you really posted this in the wrong area. the people or wedding section would be better.
AF - all point - the camera will select closest object to the camera.
group - full body shooting - like formals depends on which body - FF or Cropper you shoot with.
With a cropper - can get a large group 10-12 all in focus with f4 on 24mm L
ff - say 35mm or 50mm - you will have to drop down to around f6-ish to get everybody in focus.
focus on person in center of group (front to back).
this is a good starting point - experience will help you decide for different situations.
Wedding Photog's rule ........... just not sure what???
Gear List ~ VIAweddingPhoto(DOT)co​m (external link)
ssmanak
Joined Jun 2010
Aug 07, 2011 20:21 |  #13
Thanks. It precisely answers. Back focus by approx 3 inch at 7 feet for full height portrait.
One observation on article - as you recompose, even the verticle plane will rotate thereby further increasing backfocus.
ss.manak
kf095
Out buying Wheaties
Gallery: 64 photos
Aug 07, 2011 20:51 |  #14
I use it a lot and it helps a lot.
3 feet at 70mm on 500D is more like a macro shot, not
, IMO. ;)
yogestee
Aug 07, 2011 20:53 as a reply to  @ ssmanak's post |  #15
It's a good idea to stop your lens down to the smallest aperture possible when shooting a group photo, especially if thereis more than one row of people.
Jurgen
4,873 views & 0 likes for this thread, 12 members have posted to it.
1675 guests, 139 members online
