Thread started 07 Aug 2011 (Sunday) 19:18
Went to Kelby's class on Friday, re-edited some old photos (very mild NWS)
nathancarter
Gallery: 32 photos
Aug 07, 2011 19:18 |  #1
These were lit with my fluorescent continuous softboxes, against white seamless backdrop. My lighting skills have improved since then, but I'm still quite the novice at Photoshop.
I went to the Scott Kelby Light it-Shoot it-Retouch it LIVE! training in Orlando on Friday. I picked up some pretty good tips on quickly editing a variety of portrait styles. I took some of the editing techniques from that class, and applied them to these photos from several months ago.
Constructive advice is welcomed, especially regarding the processing.
1. Buttercup Sunset. Only some basic edits on this one - a bit of blemish removal (her skin is fantastic but she had some clumps of glitter here and there), cleaned up the eyebrows, some levels adjustment on the eyes and lips, very low-opacity skin smoothing, and a curves adjustment layer to brighten the background (was previously dull light-gray since the continuous lights couldn't blow it out). I should have done a little Liquify to clean up that odd curve on her upper arm. Also tried a new sharpening techniquethat Kelby recommended, sharpening the red channel only - not really happy with the results, so I suppose I'm not doing it right. You can see a few red artifacts from the sharpening, especially in her eyelashes.
IMAGE: http://farm7.static.flickr.com/6135/6019457525_e3214f03bf_o.jpg
IMAGE LINK: http://www.flickr.com …/nathancarter/6​019457525/  (external link)
2. Topaz le Tease. Similar edits as above, more blemish removal this time. Lightened the dark spots under her eyes. Also did a little more enhancement on the hair, though I wish I had a technique to clean up the stray hairs (not the flyaways, just the ones that aren't combed in the same direction, like that very noticeable highlighted hair on the right side of her head)
IMAGE: http://farm7.static.flickr.com/6128/6020010170_f4d1c2e22e_o.jpg
IMAGE LINK: http://www.flickr.com …/nathancarter/6​020010170/  (external link)
3. Roxie Fatale. Similar edits as above. She needed a lot more skin cleanup; she has severe acne and scars over much of her cheeks and a little in her forehead. I wanted to clean up the worst of it and smooth it just a bit, without turning her into plastic. I think I accomplished that, though I think I still have room for improvement. Also, this one really tested my skills in building the adjustment curves layer mask to brighten the background without blowing out the subject... feather boa, ack.
IMAGE: http://farm7.static.flickr.com/6125/6020013412_22715c1f6c_o.jpg
IMAGE LINK: http://www.flickr.com …/nathancarter/6​020013412/  (external link)
4. Roxie Fatale again. Focus wasn't quite perfect, but it'll do. The background needed a lot of work on this one; I only have the 5-foot-wide seamless from Adorama, and the edges were quite noticeable on both sides, and her head went up off the top of the background. I pieced together the full background by copying and pasting and Transforming the good parts. Otherwise, similar edits as above. Looks like I missed healing some of the scuff marks on the paper.
IMAGE: http://farm7.static.flickr.com/6123/6019463197_0a2a462d5a_o.jpg
IMAGE LINK: http://www.flickr.com …/nathancarter/6​019463197/  (external link)
Hollywoodgt
Joined Mar 2011
Aug 07, 2011 22:55 |  #2
U can't beat Kelby's class. I'm very much a newbie and foumd his class that you went too a big help.Pic's look great. I might have removed the face jewelry. I'm not opposed to it normally, but in your shoots it takes away from your work in my opinion, but lke I said I'm a newbie
www.Jeffreyantonphotog​raphy.com (external link) http://www.modelmayhem​.com/jeffreyanton (external link)
Bodies:5D Infared 5D MK II/5D MKIII 4 Travellites 750R
18=55mm/55-250mm/50mm Ef1.8/70-200 ef2.8L IS II/85mm 1.2L II/24-70mm 2.8L II/16-35mm 2.8L II 2X Ext II
(3) 430EX/(3) remotes/2umbrellas plus assortment of defusers
Woodworker
Aug 08, 2011 10:18 |  #3
Lovely images.
David
David
HughR
Aug 08, 2011 13:50 |  #4
Nice shots. I took the same Kelby seminar in Toronto about a month ago and also went home and very effectively applied many of his techniques. The seminar was well worth the money. One suggestion: I think a little more skin smoothing on #2 and #3 would help, but not so much as to remove all texture.
Hugh
Canon 60D, Original Digital Rebel (2003)
EFS 15-85mm IS USM, EF 70-300mm IS USM, Tokina 11-16mm
Speedlite 430EX, Speedlite 430EX II,
Qbox 16 pro, Lastolite EZbox 24x24, Lumiquest Softbox III
nathancarter
Gallery: 32 photos
Aug 08, 2011 15:25 |  #5
Thanks for the comments, Hugh.
I agree that I could do a little better with the skin smoothing; however, I'm using the technique from the class: a Gaussian blur layer, masked to only reveal the areas of skin, then reducing the opacity. With the opacity any higher than about 20%, it starts to look plasticky and fake, and I definitely don't want that - I'd rather err on the side of too much texture, than on the side of too much Photoshop.
On my Flickr page, in the "Moxie" set there are some others from the shoot using only Lightroom edits, where I smoothed the skin by simply decreasing the Clarity slider. That didn't work so well, but it'll give you an idea of what they looked like before any Photoshop.
There's a Youtube video, "the perfect lie" (I think) that shows a different skin smoothing technique, though last time I watched the video, I couldn't really follow it due to my inexperience with Photoshop. I'm gonna have to give it another look, and see what else I can do.
HughR
Aug 08, 2011 15:55 |  #6
I like Kelby's masked Gaussian blur layer technique, which I too learned at the seminar. My guess is that increasing the opacity from 20% to about 25% might just do the trick. Alternatively, you might play a little bit with the pixel range on the Gaussian Blur. As I recall, Kelby used something like 20-30, which I first thought would be too much, but actually did quite well on the photos I tried (also shot with a 60D). In your case, perhaps something smaller like 10 with a slightly higher opacity would do a better job. Just a thought. I certainly like the photos.
Hugh
1,692 views & 0 likes for this thread, 4 members have posted to it.
1686 guests, 139 members online
