I think you will find that on a number of tubes you can buy, the internal threads are designed arranged in such a way as to physically stop you fitting some attachments. This is what I have with a set of Canon LA-DC58K tubes, which means I cannot fit my wide adaptor WC-DC58B (0.75x), however, fitting the other section of tube works without problem. Basically the thread in the short tube is recessed down inside the unit, so when you try to mount the adaptor which has a short thred, the thread does not extend far enough to engage and attach properly. I also have a set of eBay tubes for G11/12, which while very cheap and cheerful, the thread on that extends to the end, so I can fit all my 58mm attachments without problem.
While this is a pain, having more than one set of tubes can be a real advantage, I basically have one setup for close up and the other for wide-angle, it is then a very simple job to swap and change when needed, without having to screw and un-screw units which can be a pain…
